Re: mechanical tach and cables - help
[Re: SSAAHemiFan]
#780583
08/22/10 07:07 PM
08/22/10 07:07 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Looks like Danny has given you some great info. I still use a cable driven tach set up and like it a lot.SW 535AH tach with the Mopar tach drive distributor,and I have a vintage Accel BEI tach drive unit to use if need be. Glad to see you're using the cable system.
[Re: Chris2581]
#780584
08/22/10 07:24 PM
08/22/10 07:24 PM
Posts: 2,431 USA
SSAAHemiFan
USA
Thanks Danny - I did contact Pegasus .. waiting to hear back - they have a adapter on there site but it is for the opposite situation I have. Have my that they have another solution ! Here is pic of the whole thing.. you can see what I am trying to accomplish.
[Re: HEMIFRED]
#780587
08/22/10 09:28 PM
08/22/10 09:28 PM
Posts: 2,431 USA
SSAAHemiFan
USA
you do realize that your problem comes from the fact that tach is incorrect for that set up? a 5" Jones/Stahl in the gold anodized bracket would be the correct one.
Yep, I'm stubborn and was hoping that an adapter or adapter cable could be made to work.. I'm a Sox and Martin fan and want to use a SW tach
If I can't make it work... Maybe we can make a deal Fred
[Re: Chris2581]
#780588
08/22/10 09:33 PM
08/22/10 09:33 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
Stewart Warner performance gauges distributor http://www.speedometersolutions.com/speedometer_cable.htm Custom Built Speedometer Cables, for any application Mechanical Take Off Speed Sensors, for aftermarket or factory speedometers, tachometers,cruise, made to suit, any mechanical drive,custom applications are our specialty Tachometer cables and drives, cars, trucks, cycles, tractors, airplanes, boats, heavy equipment Autometer, VDO, Stewart Warner, SS White, Clark Bros., Syncro Start, Arthur Allen, Dixon, AC Delco, GM, Mopar, Ford Motorcraft, Datcon, Plus many more NOS, New, Used, Rebuilt, gauges, clusters, 75 + years worth of inventory,Just ask
home of the Sox and Martin Hemi Duster
[Re: 3ddart]
#780590
08/22/10 09:41 PM
08/22/10 09:41 PM
Posts: 2,431 USA
SSAAHemiFan
USA
3ddart, Mopar Performance used to offer the cable you need - it had a black plastic sheathing instead of a metal armor. They come up from time to time at Mopar meets Here's a place that I came across while looking for a solution for myself.. http://www.texasindustrialelectric.com/speedo.aspSeem to have a bunch of SW pieces listed
[Re: dannysbee]
#780592
08/22/10 10:22 PM
08/22/10 10:22 PM
Posts: 1,466 malvern, ohio
3ddart
malvern, ohio
thanks danny, fan & fred!!!!!
[Re: SSAAHemiFan]
#780595
08/24/10 05:49 PM
08/24/10 05:49 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
I ran into that exact same issue thirty years ago, when I installed my SW mechanical tach and only had a Moroso cable.
What I did was to go to a local machine shop, left them both pieces, and they machined an adapter out of a piece of brass. As far as the end that goes into the tach, I brazed the tach end of the cable with a big clump of brass, and then took a file and filed it to fit the keyway in the distributor.
How does it work? Well, the setup is still on there and is what I use, and has been since 1974. I guess you could say it worked out.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: SSAAHemiFan]
#780603
12/13/10 04:44 PM
12/13/10 04:44 PM
Posts: 434 sweden
cuda-sweden
sweden
cool stuff.does anyone know what the device is called that makes the tachometer cable and the engine speed limiter cable run parralell to each other?who made them and what was the brand name.i have the same setup as in the pic, but with a T-brass splitter for the overspeed governor.does any of you guys have any info on that parallel cable splitter.thanks
