More magnum cyl. head help #780539
08/22/10 05:26 PM
08/22/10 05:26 PM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
Ive decided to use a set of magnum heads on my 85 360 to help bump up the comp. Ive decided on a comp xe274 cam. As I was pulling the magnum heads off at the junkyard I noticed the angle (or lack there of) on the intake bolts. I have an old school ld340 intake I was gonna use but I dont see how the bolts would work. Also, I was told to clean up the bowls and runners on the heads. Anyone have any pics of port work they did just so I can get an idea of where and how much I should remove? Thanks for your time!
"I aint here on buisness baby,Iam only here for fun"
Re: More magnum cyl. head help [Re: 1swingin] #780540
08/22/10 05:45 PM
08/22/10 05:45 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the LD 340 will not fit magnum heads..magnum intake bolts are vertical...
...also the magnum heads stock springs dont like lift over .500..the retainers hit the valve guides..
Tony
70 AARCuda Vitamin C
Re: More magnum cyl. head help [Re: 70AARcuda] #780541
08/22/10 06:07 PM
08/22/10 06:07 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Hey swingin...make sure them boneyard mag heads aren't cracked. The OEM heads seem to do that on a regular basis.
Re: More magnum cyl. head help [Re: cudadoug] #780542
08/22/10 06:25 PM
08/22/10 06:25 PM
1swingin Offline OP
1swingin  Offline OP
I ran the motor before pulling them and no signs of being cracked. It was a low mileage truck that rolled down a hill. Alot! I pulled them off and checked them. I couldnt find any. Where do they tend to crack just so I know where to look? Thanks for the heads up!
Re: More magnum cyl. head help [Re: 1swingin] #780543
08/22/10 11:43 PM
08/22/10 11:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Don't look too hard between the valves on the end cylinders, if you look hard you will find cracks there and not run the heads. Literally 9 out of 10 mag heads I have looked at have cracks there if you look hard enough but I have never seen one cause any problems.
I can, or any competant local machine shop should be able to machine the proper bolt holes in your new heads for a lot less than the price of a new manifold.
Re: More magnum cyl. head help [Re: 1swingin] #780544
08/23/10 12:01 AM
08/23/10 12:01 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
If you are going to use the Magnum style head, you will have to use a Magnum style intake, such as the M1.
Re: More magnum cyl. head help [Re: TheOtherDodge] #780545
08/23/10 12:17 AM
08/23/10 12:17 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Or drill and tap the magnum head and run an LA intake.
Re: More magnum cyl. head help [Re: goldmember] #780546
08/23/10 09:22 AM
08/23/10 09:22 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what I did.....found a machine shop that rented time for $15/hr. took an hour to drill & tap on a bridgeport. note, the LA intake bolts are NOT perpendicular to the intake face, but 7 degrees less than perpendicular.
for springs, go to hughes get their retainers for magnums and their #1110 springs. if you want to save a few $$, go to a junkyard and find some retainers off of mopar 2.2 & 2.5L, and use them with the magnum locks and hughes springs.
if you get the heads redone, sink the valves ~.030 or so to get a little more IH & retainer clearance to the seal...
2017 Grand Cherokee Overland
Re: More magnum cyl. head help [Re: patrick] #780547
08/23/10 10:14 AM
08/23/10 10:14 AM
mi
V
vcummins Offline
vcummins  Offline
V
mi
I have done this many times works great and you can run la or mag intake.
