Final Drive Ratio, #78034
06/21/08 10:29 PM
06/21/08 10:29 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
I've recently put a sure grip in my superbee,i was told the ratio was 3.23 but never checked it.
I'm pulling 3,000 rpm@65mph and am using a 15 inch rear wheel with a 275/60 tyre.
Does this sound right for 3.23?
Is there an easy way to heck the ratio without pulling the sure grip back out please?
Keeping the Bee Buzzin'
Re: Final Drive Ratio, [Re: Simonic] #78035
06/21/08 11:25 PM
06/21/08 11:25 PM
southern Idaho
moparcyco Offline
moparcyco  Offline
southern Idaho
Jack the car up put a mark on the tire and spin it around once and count how many times your driveshaft turns.That should get you close without pulling it.
Re: Final Drive Ratio, [Re: moparcyco] #78036
06/21/08 11:39 PM
06/21/08 11:39 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
that's the easiest and closest way to find out, without having to take the axle apart to inspect.
**Photobucket sucks**
Re: Final Drive Ratio, [Re: moparcyco] #78037
06/22/08 12:27 AM
06/22/08 12:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have the same tire size, but run 3.55's. 3000@65 is about what mine does. But it also depends on converter, more converter slip = more rpm, so best is to jack up the car and check like said.
Re: Final Drive Ratio, [Re: DaytonaTurbo] #78038
06/22/08 12:34 AM
06/22/08 12:34 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Thanks gents,i'll give it a try
Re: Final Drive Ratio, [Re: moparcyco] #78039
10/18/08 12:05 PM
10/18/08 12:05 PM
Tampa, FL
Saint Crispan Offline
Tampa, FL
Ok, so I put a mark on the tire and on the driveshaft, and I spun the driveshaft about 2 and one half turns to get one rotation out of the tire.
My "pumpkin" is the type that has the plate bolted on to the back of it, and it has drum brakes. The car is a 1972 Satellite (Plus), with a 400 and an automatic transmission. I think it's stock (except for having the intake on the block changed to a 4 barrel).
With 2.5 turns on the driveshaft for each one turn on the wheel, would it be safe to conclude that the ration was 2.5:1?
Is there such a ratio, standard? What is most likely the type of driveshaft I have? Is it 9&1/2"? Or 8&3/4"? Or even one I haven't heard of yet?
Thanks in advance.
Re: Final Drive Ratio, [Re: Saint Crispan] #78040
10/18/08 12:18 PM
10/18/08 12:18 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Thanks in advance.
You have a 2:76:1 (2.76's) If you driveshaft rolls the least bit past the 2 1/2 mark then I'd say you have 2.76's
Re: Final Drive Ratio, [Re: 68Bullit] #78041
10/18/08 03:18 PM
10/18/08 03:18 PM
Tampa, FL
Tampa, FL
Ah, thank you!
BTW, I used to have a 1972 Charger SE (which came with a 318 and an automatic tranny). Somebody told me that the rear end was a 2.72, and it (like my Plymouth) had a plate on the "pumpkin" (is it called a pumpkin? Who came up with that, anyway?).
Was there such a thing as a 2.72 rear end, and were they common for 1972 Dodge Charger SE's?
BTW, thanks very much for answering! (Getting some intellectual itches scratched here...)
Re: Final Drive Ratio, [Re: Saint Crispan] #78042
10/18/08 05:51 PM
10/18/08 05:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Final Drive Ratio, [Re: stumpy] #78043
10/21/08 12:44 AM
10/21/08 12:44 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
This might help. http://vexer.com/68rt/speed.html
Cheers
What a fun (and useful)little program
Re: Final Drive Ratio, [Re: Simonic] #78044
10/21/08 10:07 PM
10/21/08 10:07 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I'm running a 3:23 with 275/60 15s and turn 2500rpm @ 60mph and 3000rpm @ 70mph.
