Wheel/Tire Date Codes? #780252
08/22/10 12:50 PM
08/22/10 12:50 PM
USA
69Charger500 Offline OP
USA
How to check spare tire wheel from '69 Charger 500?
Tire is Uniroyal Glas-Belt Fastrak Belted 3781-143, 69H 167
Wheel is stamped 22, 495, & C on the inside mounting surface. Can't find a part number...
Thanks,
Mike
Re: Wheel/Tire Date Codes? [Re: 69Charger500] #780253
08/22/10 06:53 PM
08/22/10 06:53 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
The rim will have a date code around the valve stem hole.
Re: Wheel/Tire Date Codes? [Re: rrunner] #780254
08/22/10 08:55 PM
08/22/10 08:55 PM
USA
USA
Thanks, must be under the rust; all I can see is a Pentastar.
