Re: sm block harlan sharp rocker side clearance??
[Re: hp340nos]
#779752
08/21/10 04:21 PM
08/21/10 04:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I can send you some shims if need be Mike. Check your PMs.
RIP Monte Smith
[Re: CompWedgeEngines]
#779753
08/21/10 05:11 PM
08/21/10 05:11 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Harlan Sharp calls for .008-.012 side to side that is straight of there instruction sheet that came with my rockers
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: hp340nos]
#779756
08/21/10 09:49 PM
08/21/10 09:49 PM
dusturbd340W5
Kissimmee Fl.
with that much clearence you will dump a lot of oil
[Re: hp340nos]
#779758
08/22/10 10:12 AM
08/22/10 10:12 AM
dusturbd340W5
Kissimmee Fl.
I have my oil feed restricted going up top because of so much oil.
