sm block harlan sharp rocker side clearance?? #779750
08/21/10 03:46 PM
08/21/10 03:46 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
is .025-.030 between each bolt to bolt(pair of rockers) side clearance acceptable for a street/strip 340 stroker with(x-heads),rockers are 1.5 ratio h/s.the bolt holes in the head are 5/16 dia and the shafts are 3/8 hole dia.so im able to shift them some side to side.i centered the rollers on the shafts,snug then down,lightly tapped them back forth to get the .025-.030 clearances,does this sound good?or should i shim between the holdowns some for tighter clearances?thanks mike
Re: sm block harlan sharp rocker side clearance?? [Re: hp340nos] #779751
08/21/10 04:09 PM
08/21/10 04:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always use .015 for the clearance... if the heads
are off the engine you might want to drill and tap
them for 3/8 unless your running low spring pressure
Re: sm block harlan sharp rocker side clearance?? [Re: hp340nos] #779752
08/21/10 04:21 PM
08/21/10 04:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I can send you some shims if need be Mike. Check your PMs.
RIP Monte Smith
Re: sm block harlan sharp rocker side clearance?? [Re: CompWedgeEngines] #779753
08/21/10 05:11 PM
08/21/10 05:11 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Harlan Sharp calls for .008-.012 side to side that is straight of there instruction sheet that came with my rockers
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: sm block harlan sharp rocker side clearance?? [Re: dusturbd340W5] #779754
08/21/10 05:26 PM
08/21/10 05:26 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
spring pressure is 500# open pressure can is solid roller.
Re: sm block harlan sharp rocker side clearance?? [Re: hp340nos] #779755
08/21/10 06:17 PM
08/21/10 06:17 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
ok i got them down to .021-.025 side clearance im gonna leave them there.thanks for your help mike
Re: sm block harlan sharp rocker side clearance?? [Re: hp340nos] #779756
08/21/10 09:49 PM
08/21/10 09:49 PM
Kissimmee Fl.
Kissimmee Fl.
with that much clearence you will dump a lot of oil
Re: sm block harlan sharp rocker side clearance?? [Re: dusturbd340W5] #779757
08/21/10 10:11 PM
08/21/10 10:11 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i just primed the motor with cordless drill to check oiling to the top end,it had 65+ psi oil pressure with brad penn break in oil,and yes there is alot of oil to the top side.
Re: sm block harlan sharp rocker side clearance?? [Re: hp340nos] #779758
08/22/10 10:12 AM
08/22/10 10:12 AM
Kissimmee Fl.
Kissimmee Fl.
I have my oil feed restricted going up top because of so much oil.
