Thermoquad vs. Six Pack/Six Barrel. Which is best ?
#779572
08/21/10 02:36 PM
08/21/10 02:36 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Thermoquad vs. Six Pack/Six Barrel. Which is BEST for BOTH power and efficiency on the street, on both big and small blocks? Any opinions or facts?
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ?
[Re: dOoC]
#779576
08/21/10 02:59 PM
08/21/10 02:59 PM
Posts: 21,832 Kirkland, Washington
Pacnorthcuda
The PAC-man is a died-in-the-wool Berri Bum ... his opinion does not count !!
wishing you and your trees a Holley-Jolley Xmas Doc!
[Re: HYPER8oSoNic]
#779578
08/21/10 03:24 PM
08/21/10 03:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Kinda depends, lot easier to put the t-quad on a good manifold. The 6 pack problem is the manifolds not the carb, unless you are me and can't get a holley to run right for nothin. T-quads run great and are easy to work on.
[Re: HotRodDave]
#779579
08/21/10 03:27 PM
08/21/10 03:27 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
gets to be a pain to jet a t-quad when there are no aftermarket jets and rods. i have to scrounge for jets and drill them out on the lathe to get A/F ratio close.
[Re: Mr.Yuck]
#779581
08/21/10 05:36 PM
08/21/10 05:36 PM
HotRodDave
Kalispell Mt.
They only flow 1300 if you flow them a 3.0 inches like 2bbls aree flowed. If you flow a 6pk at 1.5 like the 4bbls are then it will strugle to flow 1000 cfm, or about the same as a good T-quad and you are still stuck with a 6pk manifold, a simple adapter can fit a t-quad to just about any manifold.
[Re: HotRodDave]
#779582
08/21/10 06:25 PM
08/21/10 06:25 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
HotRodDave has it right. According to the resident Mopar junky over at Hot Rod Magazine (David Freiburger,) in terms of 4-barrel air flow the mighty Six-Pack flowed closer to 975cfm because 2-barrel carbs are rated using different specs.
Throw on a street tuned Holley 950HP on an Edelbrock Performer RPM intake and there you go...
[Re: ademon]
#779583
08/21/10 06:58 PM
08/21/10 06:58 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
As someone who has run both I'll take a TQ anyday.
I have two TQ strip kits on the shelf!
