Re: Thermoquad vs. Six Pack/Six Barrel. Which is best ?
[Re: Mr.Yuck]
#779613
08/22/10 12:17 PM
08/22/10 12:17 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
He loaded it up and it backfired, Don't know how he did it but the carb never worked after that. I even rebuilt it and had a pro take a stab at it.
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
[Re: HotRodDave]
#779614
08/22/10 12:34 PM
08/22/10 12:34 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
So how many power valves do you have to replace on a six pack after a backfire?
Only one just like any other old holley out there...And if it's backfiring your not getting fuel mileage or performance tuned like that !!! ...I'll take the 6 pack thank you...I can show you the good gas mileage I get right up to the point where the other two carbs come in... ..
[Re: scatpacktom]
#779616
08/22/10 12:42 PM
08/22/10 12:42 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Tom, you and your friends have a ton of real world on track experience, no doubt, you get my full respect, and I'm not saying you are wrong or right, as I mentioned I would tend to agree that in the end a Six Pack would probably edge the TQ. However, so far have not seen any valid real world proof (controlled dyno or track testing as I described) supporting it either way, including the example you used.
Chryslers ratings were often manipulated in the name of marketing or the insurance industry, and as far as the NHRA goes, I don't agree with MANY of their factors.
[Re: scatpacktom]
#779617
08/22/10 12:45 PM
08/22/10 12:45 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Hey Scott, Here's the thing... Chrysler thinks its 15hp better, NHRA thinks its 14hp better and some guy I know thinks his car doesn't go as fast with a thermoquad. How is that for scientific?
Question- 15hp better than what, the stock cast iron 340/440 intakes?
Why yes, then you would be correct.
[Re: gdonovan]
#779621
08/22/10 01:17 PM
08/22/10 01:17 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
If need be I'll be happy to prove it. I'll have a new car coming out soon that I think would be the perfect test bed. It's a 72 400 Charger,TQ equipt of course. I'd have no problem swapping a pack on at the track,I own the parts. The car doesn't have fresh air so that wouldn't be a factor. I have the ability to set the A/F ratio in either setup to the other. I'm well versed in both setups. Its 8 bolts to me Sounds like fun I'd be willing to bet on the pack by about 3 mph. If someone out there has a B engine spreadbore dual plane aftermarket intake I could borrow I bet we could close in on the pack. We could always toss a TQ on the Bee I'm sure that would slow it right down. I would have to see if I have any 440 TQ manifolds.
[Re: ScottSmith_Harms]
#779622
08/22/10 01:19 PM
08/22/10 01:19 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Well, since we are going on looks alone I think this one is the clear winner
You win...
[Re: HYPER8oSoNic]
#779626
08/22/10 02:52 PM
08/22/10 02:52 PM
Posts: 4,766 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I have ran 2 440s with the Edelbrock dual quad package. 2 500 cfm carbs with a 1 to 1 linkage. Great great and GREAT performance and looks! I know it not a mopar OEM offering but it is an era correct hi po set up. Its about half the price of a sixpack and easier/less expensive to tune. Id LOVE to see a shootout between the Six Pack and the Edelbrock CH28 with 2 4bbls.
Keep old mopars alive.
[Re: HYPER8oSoNic]
#779630
08/22/10 03:43 PM
08/22/10 03:43 PM
Posts: 40 Corona CA
wyotech_cuda440
Corona CA
I have no experience with a tq, but I cant complain about my 6pack, it just runs good. I have used a performer rpm airgap with a carter avs- I wasn't too impressed, then I went to the sixpack on a Weiand/mopar crossram- it ran a hell of a lot better, but didn't really pull below 3k. Then I swapped to a factory sixpack manifold, low end came back strong, but it did lose a bit up top.
Daily driver: 2002 Dakota R/T, slightly modded
Weekend machine: 70 cuda, 440-6 street/strip
[Re: HPMike]
#779631
08/22/10 04:10 PM
08/22/10 04:10 PM
gdonovan
Oakdale CT
