rebuilding a small block 360 #779477
08/21/10 11:09 AM
08/21/10 11:09 AM
Oshkosh WI
barrakudaman Offline OP
Oshkosh WI
Whats a good book to read on rebuilding a small block 360. I want to freshen one up, and dont know exactly how to build short block. It is an LA engine
Re: rebuilding a small block 360 [Re: barrakudaman] #779478
08/22/10 01:44 AM
08/22/10 01:44 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
When I built my first engine I bought a copy of "How to Rebuild Small Block Mopar Engines" Still have it and refer to it often.
http://www.amazon.com/How-Rebuild-Small-...2093&sr=8-1
I think there was either an older version or maybe a how to rebuild big blocks version that was full of errors. But this looks like the same edition I have and I never noticed any glaring mistakes in it.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: rebuilding a small block 360 [Re: Michael Ecks] #779479
08/22/10 12:05 PM
08/22/10 12:05 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i used the same book to rebuild my 318, its a great source of info.
Re: rebuilding a small block 360 [Re: barrakudaman] #779480
08/22/10 01:25 PM
08/22/10 01:25 PM
Hazlet, NJ
440Satellite Offline
super gas
super gas
Hazlet, NJ
Thats what I learned with, I also like "How to Hot Rod Small Block Mopars" think thats the name. Really not much too it, just take you time, clean everything, and follow the specs for bolts, clearences, gaps, and you"ll be fine.
Any if you run into trouble, thats what this place if for
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: rebuilding a small block 360 [Re: barrakudaman] #779481
08/22/10 03:58 PM
08/22/10 03:58 PM
The one on the left. EDIT the one w errors was reportedly the BB one. this one is accurate and I still refer back to it's basics regularly. Dont know if it's the same one in the Amazon site w a different cover but it is worth acquiring
