Fuel catalyst fuel cells and run 87oct #779192
08/20/10 08:57 PM
08/20/10 08:57 PM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
Heard about in line catalyst fuel cells that go after the filter increasing octane. They supposedly make 87 regular gas like 93 . You recon they work?
Re: Fuel catalyst fuel cells and run 87oct [Re: mark7171] #779193
08/20/10 10:52 PM
08/20/10 10:52 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
wanta buy a bridge?
Re: Fuel catalyst fuel cells and run 87oct [Re: mark7171] #779194
08/20/10 11:25 PM
08/20/10 11:25 PM
Andrewh Offline
Andrewh  Offline
I believe the could work for a while.
ion exchangers and such are an old technology.
BUT how long and for how much would be the question.
Horsepower tv or one of those shows on spike show them hooking it up to a dyno engine, with 93 octane, without it, and 87 octane with it, and showed something to "prove" it worked.
But of course the question is for how long? not how long does it say it works, but how long does it really work.
A guy used to sell an empty box for 20 bucks and called it a radar jammer. Found less than 20 percent of the people bothered to get their money back.
Re: Fuel catalyst fuel cells and run 87oct [Re: Andrewh] #779195
08/21/10 01:06 AM
08/21/10 01:06 AM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
Back when it was just X,K,Ka bands there was a jammer which sent out false wide radar waves. Causing the Speedgun to read ERR, ---, and OFL on most brands of high end service meters. If you had a diplomat or fifth ave and equiped , people thought you were a cop because you would set of other radar detectors. Now nothing works for early radar detection. when they see you , you see them.
These catalysts are in magazines all over ,and the new summit cat has one setup.
