another starting question
#77834
06/21/08 01:54 PM
06/21/08 01:54 PM
Fix one problem get another.. I know i've read this on here before but here it goes. Car starts only when you hold the the key down when you release it to the run position it dies.. I have replace the ballast resister its a 74 challenger 318
Re: another starting question
[Re: cupcake]
#77839
06/22/08 08:19 AM
06/22/08 08:19 AM
Ok i've changed the ballast resister twice still the same problem when the keys all the way forward it ran just fine let off and it dies.My next step is the igition switch. I've traced the wires out of the switch. The blue wire is hot with the key in the run position the brown wire is hot when the key is forward when you let off it has no power.
[Re: terzmo]
#77842
06/23/08 08:59 PM
06/23/08 08:59 PM
I changed the horn relay or starter relay on the fender and it works fine. I think im going to change to a MSD box so i wont have to go through some of this again
