For all those that thought it was the rear end you were right(lol). I just thought since every thing was fine before the clutch install it was the clutch. I'm fine with the whole deal as I now have a better clutch set up in my car. I'm going to use the rear out of my project challenger t/a untill my original one is fixed. Mine had 3:23's and the t/a has 3:55's which should be alot more fun any way
The funny thing is we drained the fluid in the rear to see if we could see any metal peices and we saw nothing. I also tried turning the wheels while holding the pinion and we couldn't. I also checked in and out play at the tires and pinion and none, alittle at the tires but normal. Just wanted to say thanks for all the help
