When I was fooling around checking out the stock Magnum V8 ignition coil,
and the after-market alternatives,
I found in my junk pile a small 'wall wart' transformer
that put out 5 volts AC,
cut off the cord plug,
and connected the wire ends to the low side terminals of the coil,
then measured the AC output voltage of high side of the coil by measuring with an AC voltmeter from the center high voltage connector to ground.
This allows you to measure the 'turns ratio' of the internal wiring of the ignition coil.
The turns ratios of stock ignition coils usually lie in the 60 to 100 range.
The turns ratio can also be used to find the 'inductance' of the coil.
This online web app from the 'MegaSquirt Guys' allows simulating how a ignition system 'might' perform if you know some of these measurements:
http://www.bgsoflex.com/igncoil.html
