70 Cuda side marker lights #777894
08/19/10 12:44 AM
08/19/10 12:44 AM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
Sorting through some parts that came with the 70 Cuda I am short the marker light for the front passengers side. I my quest to find the one light is there any interchangeability between the other marker lights on the car?
The chrome piece that goes on the bottom of the front winshield on top of the cowl on a 70 Cuda the same for all 70 E bodies and B bodies?
Re: 70 Cuda side marker lights [Re: jml19621] #777895
08/19/10 08:22 AM
08/19/10 08:22 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1970-74 E-bodies afaik ----- and I don't think it's the same piece as 71 and up B-bodies
Re: 70 Cuda side marker lights [Re: jml19621] #777896
08/19/10 08:16 PM
08/19/10 08:16 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You'll need the specific piece that's missing...Each metal housing is different...Side to side, front or back...They all have a unique curve to follow the quarter or fender of their intended side...
Re: 70 Cuda side marker lights [Re: screamindriver] #777897
08/20/10 04:54 PM
08/20/10 04:54 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Read carefully inside each one. LF, RF, etc.
Re: 70 Cuda side marker lights [Re: Topcat] #777898
08/20/10 08:20 PM
08/20/10 08:20 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Be aware '70-'71 Barracuda side marker lights are similar to '70-'71 Fury side marker lights. They are not the same and will not interchange properly, check the part/casting numbers.
