piston ring question #777063
08/18/10 11:18 PM
08/18/10 11:18 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
I have hyperuetetic pistons and i was wondering do i have to use file to fit rings are where can i purchase rings for this. thank you
Re: piston ring question [Re: cole63b] #777064
08/18/10 11:40 PM
08/18/10 11:40 PM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
I have always used standard rings and file to fit them. with file to fit ring with Hyper pistons, you end up doing a lot of unnessary fileing and wasted money.
Re: piston ring question [Re: cole63b] #777065
08/18/10 11:47 PM
08/18/10 11:47 PM
generally file fit rings are not needed w hypers as they require a healthy top ring gap (.0065") per inch of bore for street normally aspirated iirc and normal 2nd ring gaps. I like .003" per inch on 2nd rings but alot prefer looser. File fit rings are expensive & dont waste your funds if you dont have to. Mancini has them
Re: piston ring question [Re: RapidRobert] #777066
08/19/10 07:37 AM
08/19/10 07:37 AM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
so if i just get normal rings i will still need to file them or dont have too? is basically what im getting at thanks
