motor mount conversion kit 1968 318 to fit 1989 dakota #77692
06/21/08 08:17 AM
06/21/08 08:17 AM
Anonymous OP
Anonymous OP
planing to put my rebuilt 1968 318 in my 1989 dakota but if i can get away with out having to weld up the motor mounts that would be grate. so if u have any info it would be gratly appresheated.
Re: motor mount conversion kit 1968 318 to fit 1989 dak #77693
06/21/08 09:53 AM
06/21/08 09:53 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Try Schumacher's or Imperisl Services for conversion mounts.
Re: motor mount conversion kit 1968 318 to fit 1989 dakota #77694
06/21/08 12:16 PM
06/21/08 12:16 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You'll have to use an electric fan, no room for a conventional fan in a V8 Gen. I Dakota. The '89 & '90 Shelby Dak's used electric fans for this reason.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: motor mount conversion kit 1968 318 to fit 1989 dakota #77695
06/21/08 06:22 PM
06/21/08 06:22 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Just did the exact swap. Schumakers is a great source of parts and info. I am currently running the stock fuel pump with a return pressure regulator. One wire alt made a big difference. I bought a set of headers off e-bay. Buy the conversion install kit.It comes with adaptor plates that bolt in, motor mounts and the tranny mount adaptor. Well worth the money.You will need an oil pan off of a 1990 Dakota with a 318. I found mine at car-part.com for $50. Mine was a 4 banger and the exhaust was a [Edited by Moparts - Keep it clean]. Had to shim the engine up 1/2 inch to clear the flange to the frame. You will have to buy a pusher fan for cooling and get an old style water pump to clear the radiator. Mine came off a 68' teen. Problem was the bottom is on the drivers side. Block off the fuel pump area if using the pump in the tank. I just wired mine to the key switch. Always on when key is on. I used a 727 trans and bought cooler lines for a 72 A-body. Had to shorten a little but they work great. Stock heavy radiator. If you run a mechanical gauge use copper tubing. The heat made my plastic split 2 times. Both at the block. If you have any questions e-mail me.
Shawn
