should have flushed it,but in a mad dash..
could be crap in a new lifter
could be a worn cam lobe and lifter from metal shavings
could be on the way to anothe cam wipe out
could just be an exhast leak you hear at speed
could be your a nervos nelly
could be your correct
could be the oil wiping the lobes
if this is x2 its a 50/50 chance at this time in the game..could drive it for yrs with a tick or be broke down and doing a rebuild in a couple days
not what you want to hear for sure...but IIRC,I mentioned that before you swaped cams in a mad rush
got spare moder?
