Edelbrock 1406 running rich after putting on mufflers #776640
08/18/10 02:26 PM
08/18/10 02:26 PM
Saint Cloud, MN
1963Valiant Offline OP
Saint Cloud, MN
So here's the story. I was running straight 2 1/2 inch pipes on my 318 for over a year and was getting around 18 mpg with no drivability problems. About one month ago I finally put mufflers on the car. Afterwards I reset the idle mixture screws and the initial timing to 10 btdc. Ever since then my mpg has dropped to about 10 and there is exhaust/gassy smell present in the cabin while driving. I was thinking I may have to change the metering rods or jets. Does anyone think this is the right way to go or is there something else I should check?
Re: Edelbrock 1406 running rich after putting on mufflers [Re: 1963Valiant] #776641
08/18/10 03:09 PM
08/18/10 03:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like you need to readjust the carb and advance the timing a few degrees. You did adjust the timing with the vacuum line disconnected from the distributor and plugged didn't you?
Re: Edelbrock 1406 running rich after putting on mufflers [Re: stumpy] #776642
08/18/10 05:03 PM
08/18/10 05:03 PM
Saint Cloud, MN
Saint Cloud, MN
So just advance the timing up to 12-14 btdc? I dialed it back to 10 degrees as that is what I had it at before the mufflers and it ran great. After I added them the timing was around 25 btdc and it had no power and was hard to start so I just set it back to 10.
Also, I did adjust the timing with the vacuum line from the distributor plugged.
Re: Edelbrock 1406 running rich after putting on mufflers [Re: 1963Valiant] #776643
08/18/10 05:09 PM
08/18/10 05:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
that's where I would start. Then reset the carb.
Re: Edelbrock 1406 running rich after putting on mufflers [Re: 1963Valiant] #776644
08/18/10 06:33 PM
08/18/10 06:33 PM
About one month ago I finally put mufflers on the car. Afterwards I reset the idle mixture screws and the initial timing to 10 btdc. Ever since then my mpg has dropped to about 10 and there is exhaust/gassy smell present in the cabin while driving. or is there something else I should check?
Something (some info) is missing. Put the initial back to where it was (WO muffs) and slightly readjust the mixture screws if needed.
Re: Edelbrock 1406 running rich after putting on mufflers [Re: 1963Valiant] #776645
08/18/10 07:06 PM
08/18/10 07:06 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
The timing advanced itself 15 degrees when you installed mufflers?
It's Swifty! Swifty, you toad sucker!
Re: Edelbrock 1406 running rich after putting on mufflers [Re: zrxkawboy] #776646
08/19/10 12:41 AM
08/19/10 12:41 AM
Saint Cloud, MN
Saint Cloud, MN
The initial timing was at 10 degrees before the mufflers were added. I thought that after setting the timing and readjusting the mixture screws it would work fine but for some reason something is amiss.
- It did. I was very surprised when I checked the timing that it had changed that much.
Re: Edelbrock 1406 running rich after putting on mufflers [Re: 1963Valiant] #776647
08/19/10 12:45 PM
08/19/10 12:45 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
that wasnt caused by adding mufflers
Re: Edelbrock 1406 running rich after putting on mufflers [Re: 05dakota] #776648
08/19/10 10:58 PM
08/19/10 10:58 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
