wiring gurus please help! #776540
08/18/10 12:16 PM
08/18/10 12:16 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Ok wiring junkies, I need yer help! I am wanting to swap my current alternator (whose performance has been dismal to say the least) with a late model alternator out of a 92 pickup. What is the difference in the wiring? Is it internally regulated? I currently have a dual-field externally regulated alternator. If you have any wiring diagrams for the late model alternator, that would be suuweeet!
Re: wiring gurus please help! [Re: '84 D150 Shorty] #776541
08/18/10 12:53 PM
08/18/10 12:53 PM
scratchnfotraction Offline
ez..I put a mini alt on the 440 truck in the sig pic
use an external regulated one and just crimp on eyeloops on the feild wires and trim the plastic off the batt wire
thats it...the stock VR will work and it is a bolt on
mine worked with the BB non a/c brackets and pullys
i fliped it over and used the single lug for the pivot..which moved the batt post out away from the head( they talk about grinding it down to fit)
I used some spacers and a long bolt thru both lugs as a slip adjuster
I had to make the swing are a couple inches longer was all
kinda tight at the feaild wires on the BB head and VC lip,but clears and lines up stright
there is a template in the archives you can print out for a small block swing arm
and IIRC flipping it over will do the same for not grinding the batt stud down on a SB
Re: wiring gurus please help! [Re: scratchnfotraction] #776542
08/18/10 01:57 PM
08/18/10 01:57 PM
TN
Pickup Man
Pickup Man
TN
Thanks mike! I thought the alternator I had was internally regulated, but it isn't. So it will wire up the same! Sweet! How does the voltage regulator work? Does it use a sensing wire? Is there a way to run it so it reads the voltage at the main power junction?
Re: wiring gurus please help! [Re: scratchnfotraction] #776543
08/18/10 02:01 PM
08/18/10 02:01 PM
TN
Pickup Man
Pickup Man
TN
Oh, and does it matter which wires go on which field terminal? I've wondered if they can be backwards and cause problems
Re: wiring gurus please help! [Re: '84 D150 Shorty] #776544
08/18/10 03:45 PM
08/18/10 03:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Doesn't matter which field wire goes on which field terminal.
