FUSE BLOCK #776238
08/17/10 11:28 PM
08/17/10 11:28 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
looking for a fuse block that I can run a main wire to and bring 6 or 8 runs off it no relays
Re: FUSE BLOCK [Re: dragon] #776239
08/17/10 11:54 PM
08/17/10 11:54 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Go to Summits web site and punch in Fuse blocks in the search bar. You will get a bunch of simple universal fuse blocks from Painless and others for what your looking for. mike
Re: FUSE BLOCK [Re: Sport440] #776240
08/18/10 12:17 AM
08/18/10 12:17 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Re: FUSE BLOCK [Re: Quicksilver440] #776241
08/18/10 12:48 AM
08/18/10 12:48 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That is about as cheap as it gets, But it doesnt have a Single positive feed like the OP is asking for.
You would need to make 8 positive feed connections to all those terminals. Witch is doable. I myself would step up to a single wire positive feed fuse block for less hassel.
Re: FUSE BLOCK [Re: Quicksilver440] #776242
08/18/10 12:51 AM
08/18/10 12:51 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Re: FUSE BLOCK [Re: Bob_Coomer] #776243
08/18/10 01:24 AM
08/18/10 01:24 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That does have a single positive feed but doesnt include any hardware or fuses. Plus the fuses are glass tube type
Id look at this one instead for what the OP is after, Painless 70107 or Summit # PRF - 70107
It comes with All fuses plus a big main circut breaker for the Positive feed. Plus a shorty wire Harness. All for $57.95
For the other two blocks listed you would have that plus!, with wires and fuses on your own hunt for the needed extra acessories. mike
Re: FUSE BLOCK [Re: Bob_Coomer] #776244
08/18/10 01:28 AM
08/18/10 01:28 AM
hooziewhatsit Offline
I looked through summit last night for this same thing, but couldn't find anything.
I just found these on the Bay
10 gang
6 gang
6 gang with cover
Re: FUSE BLOCK [Re: hooziewhatsit] #776245
08/18/10 12:09 PM
08/18/10 12:09 PM
wa
K
kensmachine Offline
kensmachine  Offline
K
wa
found 2 one is off a late 90s ford ranger has about 12 fuses in it its about 2.5"X8" use the bigger size fuse the other one is off a dodge van mid to late 90s has about 8 fuses and its about 2.5"X5" also use the bigger fuses ken
Re: FUSE BLOCK [Re: kensmachine] #776246
08/18/10 12:18 PM
08/18/10 12:18 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I just went to my local parts store and they had a nice one very inexspesive holds 8 push in fuses one wire feed worked out real good think it was like 58 bucks.
67' charger 499 RB 10.57 at 127
Re: FUSE BLOCK [Re: kensmachine] #776247
08/18/10 12:21 PM
08/18/10 12:21 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I got mine from here: www.waytekwire.com
just do a search on "fuse block"
