low gloss black came out too shiny #775250
08/16/10 06:31 PM
08/16/10 06:31 PM
CheddarHead till October
weedlayer Offline OP
sprayed my rear bumper (fiberglass) with a low gloss black enamel and it came out way too shiny. Cause?? Fix??
Re: low gloss black came out too shiny [Re: weedlayer] #775251
08/16/10 10:29 PM
08/16/10 10:29 PM
Ohio
tak Offline
tak  Offline
Ohio
If you used spray cans try holding the can farther away and spray more of a dry coat or spray a satin clear last. If a mixed paint, take it back and have them mix in more flattening agent. It could be trial and error to get the exact sheen your looking for.
Re: low gloss black came out too shiny [Re: tak] #775252
08/16/10 10:59 PM
08/16/10 10:59 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
If you used hardener it will generally turn out shiny. If it's spray cans, use the above advice and don't paint it in the sun.
Re: low gloss black came out too shiny [Re: Paul Jacobs] #775253
08/17/10 12:13 PM
08/17/10 12:13 PM
not a spray can. tried the Valspar implement enamel. did not use any hardener. thought the enamel would be a one shot deal and be done with it. now have a mess as in can't shoot anything else over the enamel.
Re: low gloss black came out too shiny [Re: weedlayer] #775254
08/17/10 09:51 PM
08/17/10 09:51 PM
Ohio
tak Offline
tak  Offline
Ohio
Valspar tractor paint, like from TSC ? Find a small can of Valspar or any of the tractor enamels in flat black and mix in and recoat. Start with a small amount and test on something first. I've done this with regular paints with good results.
Re: low gloss black came out too shiny [Re: tak] #775255
08/18/10 11:11 AM
08/18/10 11:11 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
It will dye back more with time. You can rub over it with a Magic Eraser to take some shine off.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
