Please explain the ACCUSUMP system
#775186
08/16/10 03:05 PM
08/16/10 03:05 PM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
I have a challenger with a World products Wedge engine.. I have Milodon oil pump with milodon oil pan with two pickups, both in the rear of the pan.. The pan has a hole in it to make room for the centerlink.. There are two - 10 hoses going to the front and rear of the oil pump.. When I pass the "stripe" and hit the brakes, the oil pump looses prime and will NOT REPRIME unless I pull the distributor and drive it will an air drill. needless to say, I have a problem with the oiling system HENCE requiring the removal of the pan and oil pump.. MY QUESTION IS,,, Where does the accusump GET it's Three quarts reserve oil from.. I am assuming that it is "charged " from one of the two oil ports in the top rear of the engine, and discharges into the "tee" that I will install into ONE of the pickup hoses????? Therefore, there needs to be a CHECK VALVE on the " fill side" to keep the oil from returning into the oil galley in the rear of the engine, when there is NO OIL pressure?????? I'm CONFUSED BIGTIME...... ![](/ubbthreads/images/graemlins/confused.gif)
Re: Please explain the ACCUSUMP system
[Re: nosboy]
#775187
08/16/10 07:55 PM
08/16/10 07:55 PM
Posts: 5,875 communist bloc of new jersey
jamesc
normally there is a valve either hand operated or electric placed in the line from the accusump to the engine. once the engine is first started you fill the accusump with pressurized oil from the engine. there is also usually a fitting on the back of the cylinder so you can put additional air pressure on the cylinder. while the engine is running (valve open) the engines oil pressure holds back the oil in the accusump. if the pressure drops the accusump pressure overcomes the loss of engine pressure and forces oil into the engine. normally before you shut down the engine you close the valve trapping pressurized oil in the cylinder. then you can open the valve before firing the engine and prelube the engine. the accusump does not discharge into the pump suction lines, it discharges back out into the same line used to fill it. the accusump is nothing more then a hydraulic accumulator.
on another note i would work on correcting the loss of suction to begin with as opposed to relying on the accusump. does the pan have a swinging pickup?
[Re: nosboy]
#775192
08/16/10 08:45 PM
08/16/10 08:45 PM
Posts: 4,213 New York
polyspheric
New York
I guess the suction hoses, at some point between the pan and the pump,, have to be HIGHER than the oil pump to create some kind of effect
That may be the problem - you have a bubble at a high point in the line that won't purge, it just expands rather than get drawn into the pump. The line should always go continuously up from the screen to the suction port.
Your pan design is also a problem - you have no forward "slosh" control. It's not difficult - you just don't have it.
This is going to sound odd, but if the pan is well sealed (valve covers, dipstick), you can prime the pump by pressurizing the case volume with air from outside while cranking.
Boffin Emeritus
[Re: jamesc]
#775193
08/16/10 09:02 PM
08/16/10 09:02 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
![](/ubbthreads/images/graemlins/iagree.gif)
Here's the thing..
If you have an internal engine problem that would cause oil pressure loss, the accusump would mask that issue and most likely cause some major problem, as you would not see an oil pressure drop. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I think they are great for start up and that's about it. ![](/ubbthreads/images/graemlins/Twocents.gif)
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 340Cuda]
#775196
08/16/10 10:47 PM
08/16/10 10:47 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I had a similar problem in the dragster, but not near a severe as yours. Upon hitting the brake the oil pressure would dive towards zero, then recover about as fast as it lost it it gained it right back... Problem is even those few seconds will cause major engine damage. Think of the accusump/accumulator as reservoir of oil with air pressure applied to one end. Pretty much a floating piston with oil on one side and air pressure on the other. Lets say the air pressure is 20 psi. Lets assume the accumulator is full and the valve is closed, so there is 3 quarts of oil pressurized inside, it cant get out cause the valve is closed. You start the engine normal oil pressure comes up in the engine say 35 psi at idle..Now you open the valve on the accumulator...nothing happens the oil still stays inside the accumulator cause the 35 psi is holding the oil inside. The valve stays open, during the run the engine oil pressure drops below the pressure of the internal pressure acting inside the accumulator, the accumulator starts to empty until there is a equalibruim of pressure, if the pressure is the same the oil stops flowing from the accumulator. Now the engine oil pressure recovers, you have 40-50 psi now the accumulator fills back up. You simply shut the valve off before you kill the engine trapping the oil for a prime before the next start, or what ever. Dont buy those expensive valves offered by moroso, and Accusump..I have a source for electric valves that are very cheap, work well... I posted some info and a link for the ebay valves... Some other good info.. https://board.moparts.org/ubbthreads/show...rue#Post6133769
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#775197
08/17/10 12:09 AM
08/17/10 12:09 AM
polyspheric
New York
I see the usual degree of interest on this. Thanks as always.
Boffin Emeritus
