E-Body brake warning light socket - where to get it?
#774914
08/16/10 10:26 AM
08/16/10 10:26 AM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
I googled for quite a while now - and cannot find a shop (online pref.) that sells them . The brake warning light socket (in instrument cluster) is different from the others (turn and high beam) - it has TWO WIRES (ground and power) and is isolated against the cluster. It's a 5/8" type.
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: E-Body brake warning light socket - where to get it?
[Re: Slotts]
#774916
08/18/10 12:00 PM
08/18/10 12:00 PM
Swiss_Robert
Switzerland, Europe
THANKS!
The socket is missing.
I have wires with enough length - I had to replace them since they were burnt (any pre-owner soldered the two together - with the result that one can expect).
I find sockets everywhere with only the power wire and grounding over the bracket - but no with grounding as second wire. I'm not looking for original looking stuff, just a 2-wire, 5/8" bulb socket...
