Re: 99 Cherokee, power windows won't go up or down
[Re: Todd]
#774724
08/16/10 09:30 AM
08/16/10 09:30 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
I usually grab the boot and lift and twist it some.If the wires broke they usually make contact.That or split the boot and have a look.I usually find more than 1 wire broken or almost broken.Rocky
Chrysler Firepower
[Re: RodStRace]
#774728
08/17/10 12:19 PM
08/17/10 12:19 PM
therocks
Niles , Ohio
The wiring for rears is pretty simple.Disconnect the motor wires.Put a test light in the 2 terminals.It should light in both positions.Its just a reversing ground.One way switch powers one and grounds one.The other way polarity is reversed.Both switchs should do the same.If it dosent Id suspect a bad master switch or broken wire in the drivers door.The rear doors usually dont open as much ad drivers door.Rocky
Chrysler Firepower
