A/c sparks #774316
08/15/10 06:55 PM
08/15/10 06:55 PM
Kentucky
dfsmopars Offline OP
Kentucky
Coming home from the Nats the compressor on my '72 Charger started throwing sparks from the clutch. Is the compressor locked up or is the problem in the clutch?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: A/c sparks [Re: dfsmopars] #774317
08/15/10 07:13 PM
08/15/10 07:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Problem with the clutch, I'd almost guarantee it. They go bad, I recently replaced one.
Re: A/c sparks [Re: Challenger 1] #774318
08/15/10 09:42 PM
08/15/10 09:42 PM
Kentucky
Kentucky
I have no problem tearing into it but are there any pointers anyone wants to share? Are parts available?
Re: A/c sparks [Re: dfsmopars] #774319
08/16/10 11:25 AM
08/16/10 11:25 AM
Missouri
ShelbyDogg Offline
ShelbyDogg  Offline
Missouri
Could have been from your compressor locking up or slowing down due to high head pressure. The clutch was slipping. I had my a/c on while crusing Heath and on the highway from Brice. The clutch puts out a unique smell while it is slipping. I would smell it inside the car once i a while and sometimes hear it squealing.
Smell anything funny?
To pull the clutch off, I take off the little bolt in the middle. pop the clutch plate off, then use a big bolt that threads into the clutch and pulls the clutch off. Years ago I was looking for a puller and never found one. I found out that you just need a threaded bolt to pop it off.
I think it is a 5/8" coarse thread.
Rob
3 E-bodies, 70 Challenger R/T, 71 Challenger Vert, 72 5.7 HemiCuda
Rob del Rosario on FB
Re: A/c sparks [Re: ShelbyDogg] #774320
08/16/10 11:55 AM
08/16/10 11:55 AM
Kentucky
Kentucky
No smell just sparks. I have run it since converting to R134 two years ago. I first heard it squeal heading home on 70 so I turned it off for the remainder of the trip. When I stopped for gas I had my son watch it when I turned it on. It squealed again and that's when he saw the sparks.
Re: A/c sparks [Re: dfsmopars] #774321
08/16/10 05:10 PM
08/16/10 05:10 PM
PA
70Duster Offline
70Duster  Offline
PA
When you converted to 134A, did you add oil that is compatible with 134A? If not, the compressor may be locking up.
Re: A/c sparks [Re: 70Duster] #774322
08/16/10 06:11 PM
08/16/10 06:11 PM
Missouri
ShelbyDogg Offline
ShelbyDogg  Offline
Missouri
Now is the time to decide whether to convert it to the new compressor. 38 hp to drive the RV2 style or 3HP to drive the new rotary vane style.
You'ld have to modify your brackets to move it towards the driver's side but it can be done. A friend has one on his small block 73 Chally.
I got a rebuilt RV2 compressor from Oreilly's before the power tour. It was $125.
Rob
Re: A/c sparks [Re: ShelbyDogg] #774323
08/16/10 08:46 PM
08/16/10 08:46 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
funny you posted this. our 73 charger has a/c and the clutch locked up while driving on the highway, no sparks but the belts just dragged across the pulley and melted off
Re: A/c sparks [Re: dfsmopars] #774324
08/16/10 11:09 PM
08/16/10 11:09 PM
Kentucky
Kentucky
We did put the correct oil in it when we converted it. Acutally I have too much money in the system: new dryer, new expansion valve, all new o rings, vaccumed out and recharged.
But yes I am considering putting in a new system. Does it really free up that much HP? I know it would remove a lot of weight. If it is only the clutch I'll replace it and keep trucking until I pull the engine. I'll pull the clutch tomorrow and think about the whole deal.
Thanks for everyone's help and stories.
