How to order a 'matched set' of alt-a/c v belts? #774180
08/15/10 03:35 PM
08/15/10 03:35 PM
IL
furious70 Offline OP
IL
Having trouble with one being slightly longer than the other and not getting an even tightness. Someone said you can request a matched pair (having the same lot number), but I just called Napa and they had no idea what I was talking about. Is it still possible to do this or do parts houses not understand anymore that some cars used to take a pair of v belts?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774181
08/15/10 03:57 PM
08/15/10 03:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
NAPA did carry matched sets.Ive bought several years ago.You need to find someone that can read a book instead of a computer.They are called matched sets.I know Advanced used to carry them also.What are they for?My kid works at Advanced maybe he can get a part no.Rocky
Chrysler Firepower
Re: How to order a 'matched set' of alt-a/c v belts? [Re: therocks] #774182
08/15/10 04:21 PM
08/15/10 04:21 PM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
I tried to get a set for my 66' Coronet a couple years ago and was told there was no such thing
I finally found a Carquest that had someone who knew what I was talking about. He said that it was a thing of the past as they are made to "exacting" standards and are all the same. I protested but he insisted all would be well. So I ordered them and they wouldn't work. One was flopping around really bad and the other nice and tight They took them back and I found myself at a Advanced Auto parts next. He ordered in like 5 or 6 of them and I picked the two that measured up similar on the belt measurer they had.
Not perfect but close. Haven't had any issues with them.
Sad thing is not 10 years ago was able to get them no problem for my 69' (matched set)
Good luck on your search
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774183
08/15/10 04:26 PM
08/15/10 04:26 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Find the existing PN for your application, let's say it's a Gates 5120-445. The last 3 digits of the PN is the length of the belt. If you need a 2" shorter belt you'd order PN 5120-425.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774184
08/15/10 05:31 PM
08/15/10 05:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
JB,...matched sets are still available, most parts store dummies have no clue what a matched set means,....when a belt is made, it starts life as a long tube that gets turned (cut) in to the desired V rating (width and profile) numbers are stenciled along the belt in a progressive series along the width, ...example 33345 and 33346 are matched, 33345 and 34478 are not, it was cut further down the tube, which may be smaller or wider in diameter,....the BS line that all belt are now built to exacting standards is BS,....find a parts store that can supply your request
Re: How to order a 'matched set' of alt-a/c v belts? [Re: DAYCLONA] #774185
08/15/10 06:54 PM
08/15/10 06:54 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
All the belts should have a lot number on them. Find 2 with matching lot numbers and you should be good to go.
Automotive V-belts in matched pairs would be a thing of the past with everything having serpentines on them now.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: DAYCLONA] #774186
08/15/10 07:12 PM
08/15/10 07:12 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
May be the case with some but not with Gates.Just went through the same thing.
What I was told:
All of our v-belts a formed ground (cut) and are within 1/,1000 of inch tolerance from each other. When the dealer told you all belts are matched, he was telling the truth. With that said, a few years ago we changed the design of the inside cogs of the belts. Please see if the cogs match each other. You will also see a code in red ink on the belt (example:238SS). That tells the run date and location. If those numbers are close or the same, that means the belts were mfg on the same spool.
Regards,
DAVID SLATER
Territory Sales Manager
Gates Automotive / Heavy Duty Aftermarket
Re: How to order a 'matched set' of alt-a/c v belts? [Re: 62maxwgn] #774187
08/15/10 08:12 PM
08/15/10 08:12 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
We don't seem to have much luck finding sets either. Even when we got a set they didn't tighten up evenly, that set was Gates.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: rrunner] #774188
08/15/10 10:08 PM
08/15/10 10:08 PM
dart1962_440 Offline
I just got a/c belts from Rockauto.com - you had to order each belt separately but they showed up as a matched set.
Pat
Re: How to order a 'matched set' of alt-a/c v belts? [Re: dart1962_440] #774189
08/15/10 10:52 PM
08/15/10 10:52 PM
IN
ahy Offline
ahy  Offline
IN
I've given up trying... but done OK buying seperate belts. They are never exactly the same tightness but close enough to be functional. I generally re-adjust the belts after a while and the tighter belt stretches more than the loose one and they are real close at that point.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: ahy] #774190
08/15/10 11:28 PM
08/15/10 11:28 PM
IL
IL
These were Duralast 15610's. I don't know who makes the belts for AZ, it wasn't clear on the band. This is a bit longer than stock 70 383 with a/c because I'm running a GM case alternator that is swung out a bit more to clear the head. These belts are a touch wide to sit into the grooves as nice as I'd like but I think that is the price paid for the longer belt.
It was _ok_ without the a/c on, but 1 really flopped with the a/c on, and it kicked that belt when I went racing last month. Been running with just the 1 belt but it has started to squeal some with the a/c on, can't hold both it and the alt drawing power for the EFI ecu and fuel pump apparently.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774191
08/16/10 12:21 AM
08/16/10 12:21 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
I have a few sets of matched Mopar AC belts. Let me know what part no and brand you are using now so that I can cross referance to get the right length. These are also the narrow correct width belts that these cars called for. PM me for more information.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774192
08/16/10 08:53 AM
08/16/10 08:53 AM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
ive been in the parts bizz for 14 years now . it used to be really easy to order matched sets. not so easy anymore. what i usually have to do is order 4 or six of the same part number to get 2 that are matched. now quit giving the poor parts people crap about it. and just so we are clear, most of us can read .
71 scamp big block with 915 heads 727 trans
Re: How to order a 'matched set' of alt-a/c v belts? [Re: 71scamp440] #774193
08/16/10 11:16 AM
08/16/10 11:16 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
My
Own
Personal
Adrenaline
Rush
Re: How to order a 'matched set' of alt-a/c v belts? [Re: Moparzrule] #774194
08/16/10 11:58 AM
08/16/10 11:58 AM
IL
IL
great link, going to head over to Napa with that on my Droid X and show it to them, maybe that will jar someone's memory!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774195
08/16/10 04:15 PM
08/16/10 04:15 PM
IL
IL
well that was an extremely painful conversation over at napa, even armed with all that data from the gates site the computer jockey at Napa was completely unable to grasp what I was trying to get at.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774196
08/16/10 05:46 PM
08/16/10 05:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Goodyear has a line of belts called The Matchmaker that hold the same length tolerance no matter where they're made.
Our local NAPA warehouse will send somebody "upatairs" to visually match mold numbers when matching belts are ordered.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: John_Kunkel] #774197
08/16/10 07:38 PM
08/16/10 07:38 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
if you strike out at the parts store look up a industrial supply house or even a tractor or larger mower dealer. (JD, New Holland, CAT)
They are used to dealing with matched belt request's.
I change them all the time on our air handlers and cooling tower.
One has 6 belts per cog
Re: How to order a 'matched set' of alt-a/c v belts? [Re: SSAAHemiFan] #774198
08/16/10 10:15 PM
08/16/10 10:15 PM
Central, Indiana
mc4406 Offline
mc4406  Offline
Central, Indiana
Let me know what belts you need, I sell belts mostly agriculture but can get automotive and I know what matched set means..lol If I can be of help to anyone just shoot me a message. The brand name is PIX, I used them on my 70 440 a/c R/T with no problems. Belts are made alot different then people think.
Re: How to order a 'matched set' of alt-a/c v belts? [Re: furious70] #774199
08/17/10 05:01 AM
08/17/10 05:01 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
PM me with your phone number and I can help you out. Also a time I can reach you at the number. I can explain to you about matched belts.
