Dana 60 questions, my plan....... #7726
12/12/03 10:19 PM
12/12/03 10:19 PM
an8sec70cuda Offline OP
well, the way my car's runnin right now i dont think the 8 3/4 will last much longer. so im gonna put a Dana in it here's what im planning.....
get a Dana 60 from the junkyard, will probably have floating axles
strip it down, get a new spool, bearings, and gear set
weld on my old 8 3/4 axle ends....so i can reuse my original brakes and 35 spline axles from the 8 3/4
im gonna make the DANA the same width as the 8 3/4.
i guess my biggest question is will my axles work??? having them cut down and resplined is no big deal, but does the dana have a weird offset axle length or anything?
im thinking since its gonna be the same overall width and itll have a spool that the axles should work. am i on the right track???? thanks, CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7727
12/12/03 11:12 PM
12/12/03 11:12 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Chip, sounds like a plan, that was what I planned to do when I put the dana in my car, made it the same width as my 8 3/4, but the axles would not work, I had a set of strange in mine, and they are broached on the ends, the strange brand cannot be cut and resplined, most other ones can be if they are not a broached set of axles, if you have moser, or some other brand, they can be cut and resplined, that's what I put back in mine was a moser, cut the housing, put new ends on, had all the brackets welded, new spool, gears, bearings, wound up with just a smidge under a grand invested in it, go for it, you csan'tgo wrong, by the way it picked my car up, .005, in the 1/8. go figure, and there is only a 27 lbs, difference in wt., at least that's what mine was. Thanks Dave
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7728
12/12/03 11:15 PM
12/12/03 11:15 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Chip a few things...
The ends are the same on an 8 3/4 and Dana. You will just need to swap out your brake stuff.
The axles on a Dana are different size from one side to the other.
The 35 spline axles should work, but I am not 100% sure about that. The spline angles may be cut different on a Dana.
IF you have to cut off the ends of the Dana for some reason, that would be the time to shorten it a tad, especially since you have to cut your axles down.
Hopefully, you can get REAL lucky and find a B Body Dana which will be about 1 3/4 inches narrower than an E-body Dana. That is what happend to me and it gave me some extra room.
Good luck! James
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7729
12/12/03 11:20 PM
12/12/03 11:20 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Hey Chip,
Are your existing axles aftermarket? I thought 8 3/4 axles were 30 spline. My Dana axles are different length from one side to the other. If you make the new axle the same length & offset as the 8 3/4, you should be fine.
Re: Dana 60 questions, my plan....... [Re: STEFF] #7730
12/12/03 11:22 PM
12/12/03 11:22 PM
Houston, Texas
Houston, Texas
Steff, I don't want to answer for him, but IF he does have 35 spline, they would have to be aftermarket, because as you say, stock was 30.
Re: Dana 60 questions, my plan....... [Re: TheOtherDodge] #7731
12/12/03 11:25 PM
12/12/03 11:25 PM
Marion, SC USA
69RR383 Offline
69RR383  Offline
Marion, SC USA
They are Moser IIRC.
Re: Dana 60 questions, my plan....... [Re: 69RR383] #7732
12/13/03 12:53 AM
12/13/03 12:53 AM
thanks for the replies yall. yep, like my dad said, these are 35 spline Mosers in my 8 3/4. so everything will work, ill just have to have my axles cut and resplined as necessary.
the Dana 60 ill be getting will most likely come out of a truck from the junkyard. no problem doing the narrowing and welding on it, ill get that done. ill make it the exact same width as my 8 3/4 so my rims will still have the same clearances. they're right where i want em as of now.
do yall have a general estimate on what Moser would charge to modify my axles??? thanks again, CHIP
CHIP
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7733
12/13/03 01:05 AM
12/13/03 01:05 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Dana axles are 1-1/4" or so different in length. I bought a set of moser axles for the dana I'm doing like you and they are equal length. So one will get cut to compensate.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Dana 60 questions, my plan....... [Re: Silver70] #7734
12/13/03 04:41 AM
12/13/03 04:41 AM
chip, you wont have to cut the axle shaft, just have to get the pinion offset right. get ahold of dr.diff, he's an expert on this!
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7735
12/13/03 08:15 AM
12/13/03 08:15 AM
pa
572charger Offline
572charger  Offline
pa
10sec, there is no place to put a pinion snubber if you are useing leafs??
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Dana 60 questions, my plan....... [Re: 572charger] #7736
12/13/03 10:45 AM
12/13/03 10:45 AM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Chip what Dusterjohn said.
Are you still running CalTracs?
I just had my Truck axle set up like this.
Jeff
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: Dana 60 questions, my plan....... #7737
12/13/03 12:22 PM
12/13/03 12:22 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Chip - Here's a different approach. How about selling the 8 3/4 complete minus brakes (should get at least $600) and use that money to offset the cost of a bolt in deal from Strange for 1450? Just a thought...
2 kids and a dog
Re: Dana 60 questions, my plan....... [Re: tilt] #7738
12/13/03 10:02 PM
12/13/03 10:02 PM
Dusterjohn....so i dont have to cut the axles down? sounds good to me.
572charger.....i dont use a snubber. back when i had SS springs the car 60 footed .05 better w/o it.
Tilt....yep, still got the Cal-Trac setup on it.
TonyS451.....well, i have thought of that, but i think i can come out pretty good doing it my way, and ill know the job is done right. dont get me wrong, i know some companies do great work, but if I didnt put it together or personally know the guy that did, i dont trust it.
preciate the help yall CHIP
CHIP
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7739
12/14/03 10:25 AM
12/14/03 10:25 AM
Hey CHIP,
Copy Cat .... I'm putting in a DANA as well. I have a guy who has a NEW DANA housing, tubes and brakes for $600. However, Once I spec it out, adding parts, setup and axles, it's within $100 to just get a Strange Unit ready built and delivered. That's what I'm doing.
Moser has a prebuilt housing for $1550ish, it's $85-95 to cut and respline IIRC. I'm keeping my 35 spline MOSERS for use on the 8.75" if it ever goes back for normal streeting use. I'm pretty sure MOSER said both axles would have to be modified. On my stock width, that meant ONE might not be long enough due to the offeset.
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7740
12/14/03 11:29 AM
12/14/03 11:29 AM
jax. fla.
70Dustmite440 Offline
jax. fla.
i am wondering just what was done to mine...i bent an axl tube on my 8 3/4...well the local guy that did the shorting on it(8 3/4) told me that he cuts down a dana for my moser axl.(from 8 3/4) and puts them in a cut down truck rear, and that is what he did....now..the 8 3/4 was stock spline, did he re spline for the dana... i didnt even count the spline when i put the thing together... the truck rear is a stock rear. gear, etc.
hey chip....
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: Dana 60 questions, my plan....... [Re: 70Dustmite440] #7741
12/14/03 12:20 PM
12/14/03 12:20 PM
Alberta, Canada
K
ktbundy Offline
super gas
ktbundy  Offline
super gas
K
Alberta, Canada
I am doing almost the exact same thing, as I am using 35 spline Strange axles from an 8 3/4 and putting them into a Dana. My understanding is that by using equal length axles, this will offset the center of the Dana. Meaning you would want to check driveshaft angle if your motor is mounted in the traditional manner(off to the right). I am making new mounts for mine anyway, the the motor will probably sit in the center.
Tom
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7742
12/14/03 04:39 PM
12/14/03 04:39 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Do yourself a BIG favor...don't cut your 8 3/4 ends off and reuse them.Buy a set of new housing ends,you'll be much happier when it comes time to weld.
Nautilus Racing-
Re: Dana 60 questions, my plan....... [Re: Chris2581] #7743
12/14/03 04:58 PM
12/14/03 04:58 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Competition engineering sells the new ends for the mopar car type.
Jeff
Re: Dana 60 questions, my plan....... [Re: tilt] #7744
12/14/03 05:03 PM
12/14/03 05:03 PM
we've reused old axle ends MANY times w/ no problems. thanks for the info though.
well, i reckon ill wait and talk w/ my chassis fab friend and see what needs to be done about the axles. obviously i'd like to get by w/o resplining the axles, but if it has to be done, so be it.
im gonna stop by the junkyard tomorrow on my dinner break and find a rearend. then go from there....
oh....one more question.....are all Dana 60s the same? i mean do they all take the same bearings, gears, and spools??
thanks yall, CHIP
CHIP
Re: Dana 60 questions, my plan....... [Re: an8sec70cuda] #7745
12/14/03 06:29 PM
12/14/03 06:29 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Better check the man,DR. Diff.
Btw i paid $ 150 for my donor out of a 72 ford P.U. and it already had a 4.10 in it.
Jeff
