comp/leakdown test results...need help
#773163
08/13/10 11:45 PM
08/13/10 11:45 PM
Posts: 69 Menomonie,wi
menomoniemopars
Menomonie,wi
Guys got to working on my 340 challenger again.. we did a comp test first and then a leakdown.. the engine was cold, but it gives us a baseline to go by.. what I found is quite odd and I am not sure what it all means? Can u look at the following pic and let me know your thoughts! Something is wrong somewhere ,but where? When @ TDC #1 the balancer is at zero or close to it and rotor pointing at #1 also, I get comp not real good ,but good enough, but when i do a leakdown on that cylinder it's basically dead along with 3 others.I only took it to 70 psi to test it with incase anyone wonders, also I could not hear leakage from anywhere? a little out breathers ,but thats it!,nothing out exh or thru carb, thats why I am baffled!.Also #2 cylinder is very high too!. is it cam timing? or what? Also the car starts and runs not too bad, is responsive and throaty too , but isn't making alot of vacuum like 7-9? Smokes some too off and on.. and has it warms up has a inner knock what sounds like inside the motor somewhere too.. the oil has been checked and filter cut open no bearing stuff!... At this point were going to pull it and have it gone thru. unless u guys see something we don't
Re: comp/leakdown test results...need help
[Re: menomoniemopars]
#773164
08/14/10 01:16 AM
08/14/10 01:16 AM
Posts: 7,506 Az
Crizila
Az
Looks to me like something is wrong with your test proceedures. Did you run the comp test with the carb butterflies open, plugs out, and do the same number of pumps for each hole? Looks like you did some of the leak downs on the overlap stroke. Are you sure you were on the comp stroke for all 8 cylinders on the leakdown test? The car would not run "ok" if those numbers were real - although the vacuum is real weak - should be double that.
Fastest 300
[Re: Crizila]
#773165
08/14/10 10:35 AM
08/14/10 10:35 AM
menomoniemopars
Menomonie,wi
Hi thanks for the reply. yes I held my finger in the plug hole for each til it blew my finger out,verifying i was on the compression stroke then manually moved it so it was exactly at TDC, each test was done with 4-5 pumps each hole. Carb was wide open also.
#773166
08/14/10 12:23 PM
08/14/10 12:23 PM
Posts: 7,506 Az
Crizila
Az
Comp test; looks like you ran 3 tests on #2 and got a variation of 40 psi?? Something changed. Maybe cranking rpm? The leak down test should have been run with 100psi input. The lower the input pressure the greater the leak rate will be as the higher pressure will push the rings against the ring lands and make a better ring seal. Even at 70 psi input, with 15 psi on the "leak gauge", you should have been able to hear / feel the leak. Just to verify that you have a problem with the holes that show a major leak, I would run an rpm drop test. Run the engine at a steady idle rpm and pull the plug wires off 1 at a time and record the rpm drop for each hole. If your suspect weak holes line up with holes that show very little rpm drop, time to pull it apart.
Fastest 300
#773169
08/14/10 06:25 PM
08/14/10 06:25 PM
Posts: 7,506 Az
Crizila
Az
Think you need to take the motor down all the way and check it over. Just too many issues and unknowns. Sorry I couldn't help more, but that's what I would do at this point.
Fastest 300
[Re: Aspen7695]
#773171
08/14/10 07:13 PM
08/14/10 07:13 PM
menomoniemopars
Menomonie,wi
I honestly don't know if there stock or not Is there a way to tell? This is a 69 340 with X heads, has 2.02 int valve.Only single valve springs tho? is that stock? I am actually helping my brother on this car it's his car I am A pontiac guy,lol.. so not too familiar with the rocker set up on these dodges? I know there shaft mounted and when i loosened them they seemed tightened down tight. Not adjustable like mine..Thanks guys!. this is a pic of my car.ran [Email]11.95@114[/Email] on a new motor @ 4600 pds..pump gas 91.. 560 Hp.. 600 ftlbs
#773176
08/15/10 04:47 AM
08/15/10 04:47 AM
RapidRobert
Might pick a cyl that's at TDC & make a mark on both of that cyls pushrods up top in the valvetrain area referenced to something stationery nearby (for a height change measurement)then bolt on the rocker arm assy and measure how far it depresses the 2 pushrods for a preload measurement. I thought I read that you are able to depress the valve springs w your finger but they cant be that weak.
[Re: 451Mopar]
#773182
08/16/10 09:25 AM
08/16/10 09:25 AM
menomoniemopars
Menomonie,wi
I didn't do any oil on leakdown only on the comp test.and that helped very little.. ,but after i removed the rockers shafts on the heads i had good readings, so something in the valvetrain geometry is screwed up... cam is unknown, need to get a pushrod tester and find the proper length for the right preload..
