Caltracs with Stock leafs #773034
08/13/10 08:33 PM
08/13/10 08:33 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys,
Im working on the suspension of my 71 scamp as some of you guys on here already know...Ive had a few leads of what direction to go in, and have been offerred a set of SS springs, but not sure how long its going to be before i see them, and id like to fix the suspension and get the car out again this year for a few passes to see if it will hook.
That being said, I called calvert awhile back and talked with them about their bars. I know they flat out work for 95% of the guys out there, so im thinking of picking up a set with the rancho shocks and their 90/10's. However, i know that the monoleafs arent exactly the most street friendly and my car is 90% street car (contradictory to the tech guy at calvert who said the monos should last at the very least a couple years on the street). Id like a decent ride, and from what i hear the monos dont have that (could be that guys are running them on the street the way they have em adjusted for the track, not sure though)
Im wondering how well the caltracs work with factory leaf springs. I have 6cyl leafs with a leaf added to each to stiffen them up and bring up the height some. When calvert first came out with the caltracs as far as i know they had no monoleafs and their stuff stil worked...or did it not? im looking for your guys opinions on running them with the stock leafs on my car...how well would they work? would i have to remove that extra leaf i added for stiffness as it may work against the caltracs? ive never really seen this question asked before, so i figure it would be good to see whos running them like this
any input is appreciated!
thanks guys!
Matthew
Re: Caltracs with Stock leafs [Re: mshred] #773035
08/13/10 08:43 PM
08/13/10 08:43 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I ran them on my Duster with great results..1.40 60ft's with a pump gas .509 cammed 440. I disassembled the old springs and put them together using the stiffer springs in the right side. 1/2 turn of preload in the right and the left just touching the spring..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Caltracs with Stock leafs [Re: Eric] #773036
08/13/10 09:44 PM
08/13/10 09:44 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I run my stock 40 year old 318 springs with Cal-Tracs. 1.5 60s for a street car is not too bad. I like this combo and I doubt that changing to their monos would pick up the 60 enough to offset the expense, trouble, and questionable reliability. Besides, the car doesn't ride too bad like this.
Master, again and still
Re: Caltracs with Stock leafs [Re: DaveRS23] #773037
08/13/10 09:46 PM
08/13/10 09:46 PM
Idaho
Runner Offline
Runner  Offline
Idaho
how noisy are they on the street?
Re: Caltracs with Stock leafs [Re: mshred] #773038
08/13/10 09:50 PM
08/13/10 09:50 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
... However, i know that the monoleafs arent exactly the most street friendly and my car is 90% street car (contradictory to the tech guy at calvert who said the monos should last at the very least a couple years on the street). Id like a decent ride, and from what i hear the monos dont have that (could be that guys are running them on the street the way they have em adjusted for the track, not sure though)
I have ran my calvert monos for 5 years on the street...they are just fine.
And they ride better than SS springs.....Especially if you replaced the front aluminum bushing with a poly or rubber one (I ran a rubber one for a few years and it rode great with the bars backed off).
Re: Caltracs with Stock leafs [Re: mshred] #773039
08/13/10 10:49 PM
08/13/10 10:49 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Have had Caltracs and 1/2" mono leafs on street cuda since '98. no problem, ride is fine, .090 gap between spring and stop.
just some rattles, had my springs made at local spring shop per Calverts specs before he sold leafs.
Multi leaf acceptable as long as they are symetrical, no bias.
Re: Caltracs with Stock leafs [Re: mshred] #773040
08/13/10 11:15 PM
08/13/10 11:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have no problems w/the cal-trac system on the street at all. Loosen the shocks, take out pre-load and it`s a nice ride and when you race just tighten up the shocks and add the desired pre-load and you`re good to go. You hear all kinds of different opinions and you just have to make your own based on those I guess.
Re: Caltracs with Stock leafs [Re: Thumperdart] #773041
08/14/10 04:46 AM
08/14/10 04:46 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Any pictures of your ride height at rest with the mono's? Do they sag after a while. I was gonna just put their bars on my XHD springs but they aren't a symetrical spring so I was a bit worried about that.
Re: Caltracs with Stock leafs [Re: mshred] #773042
08/14/10 10:37 AM
08/14/10 10:37 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
the leaf only has to hold the car at the desired hgt.
Once caltracs are installed they controll axle windup.
Do you have local access to a spring manufacturer?
someone make truck springs/repair?
I think I still have print laying around.
or just use a set of good 4 leaf slant six dart springs. think they are symetrical.
If you have a spring pile you could take the leafs apart and make you own set as long as they are the same dimensions.
Use a heavy main leaf and a few smaller ones to suite your ride hgt desires.
Re: Caltracs with Stock leafs [Re: MoparDonny] #773043
08/14/10 12:29 PM
08/14/10 12:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t have any photos but mine are at least 7 years old and can`t really tell if they`ve sagged or not. They are symetrical and I love em WAY more than ss springs.
Re: Caltracs with Stock leafs [Re: Thumperdart] #773044
08/15/10 11:52 AM
08/15/10 11:52 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey guys,
i appreciate all the responses! Part of the reason why im wondering if the caltracs will work with stock springs is the cost of the mono's...im surprised that so many have had good results with the monos, both on the street, and on the track...when i talked to calvert he said the most they get out of their monos is about 4 years, and thats on race only cars...question though, if i back off the preload and shocks for the street, will the car not hook at all for the odd stoplight blast?
Also, if i do end up using my stock springs, i was going to remove the added leaf, but im not sure what you guys mean by the whole symetrical spring thing and making sure the springs i use are...the springs i have are stock 6cyl leafs, so i was thinking of removing the leaf and getting them both arched the same and using them...make sense, or are you guys talking about something different?
thanks for all the replies thus far btw! im even considering the monos now if money permits!
Re: Caltracs with Stock leafs [Re: mshred] #773045
08/15/10 12:00 PM
08/15/10 12:00 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
equal length and same thickness of segments.
side by side they are identical.
no preload on street is fine, you shouldnt be worried about max et on street anyway... save it for the track, enjoy cruisin for what it is.
Re: Caltracs with Stock leafs [Re: theclutcher] #773046
08/15/10 01:58 PM
08/15/10 01:58 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
so would factory 6cyl springs be the same length and equal thickness as well? if i read your other post correctly, you mentioned a diagram or dimensions or something, were they of symetrical springs? also, im not worried about street racing, but its nice to have a little fun sometimes...just wondering if the car will hook at all with no preload
Re: Caltracs with Stock leafs [Re: mshred] #773047
08/15/10 02:21 PM
08/15/10 02:21 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
stock s6 springs on my sig pic, just moved in. for ride hight ref tire is a 29.5x10.5.
Re: Caltracs with Stock leafs [Re: Randy..] #773048
08/15/10 04:42 PM
08/15/10 04:42 PM
Renton Washington
Triple Threat Offline
Renton Washington
As other have already stated, mono's are no problem on the street. The big pain, literally, is if you run the bars with preload in them. I have everything Calvert offers; bars, monos, 90/10's and ranchos. I drive the car the same way I race it. Stop and go traffic, to and from work, always the same. I do have preload in the bars, so it rides about like a 1 ton truck.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Caltracs with Stock leafs [Re: Triple Threat] #773049
08/15/10 05:40 PM
08/15/10 05:40 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
its good to hear that both with stock leafs and the monos the setup works, and its also good to know that the mono's without preload drive fine..triple threat, do you ever drive on the street without preload? would having preload on the street wear out the monos faster you think? i like my car to be ready for action wherever i am lol
also, another question for everyone, what pinion angle do the caltracs like? i have mine currently set somewhere around 5 deg. nose down, but im wondering if im going to have to shim it at all for caltracs
thanks!
Re: Caltracs with Stock leafs [Re: mshred] #773050
08/15/10 05:44 PM
08/15/10 05:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My pinion angle is bet. 4 1/2-5 degrees nose down and I drive w/about a 1/4" gap on the street w/shocks on 1 or 2 settings and race w/a flat or two preload on the pass and just touching on dr. side w/the shocks on 4 or 5 w/rancho 5-ways.
Re: Caltracs with Stock leafs [Re: mshred] #773051
08/15/10 05:48 PM
08/15/10 05:48 PM
Renton Washington
Renton Washington
Mine always have preload, I'm too lazy to adjust the bars twice a week. Considering I race the car nearly every weekend and drive it around M-F I just leave it alone and deal with a little stiffer of a ride.
As for wearing out the monos I'm not sure, and I haven't given it too much thought. Theoretically every time the spring compresses and rebounds it wears out a little bit. As for if the bars compound that action I would guess no, but I've been wrong before.
-Dustin
-Dustin
Re: Caltracs with Stock leafs [Re: Triple Threat] #773052
08/15/10 06:28 PM
08/15/10 06:28 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
-Dustin
how long have you been running the setup like this for? do you know what your pinion angle is roughly or what calvert recommends?
Thumper, thanks for your specs, i appreciate the info!
Re: Caltracs with Stock leafs [Re: mshred] #773053
08/15/10 06:36 PM
08/15/10 06:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No problem..............I`d go w/the complete cal-tracs system instead of just the bars but, that`s just me.
