Re: Okay, what's the secret?
[Re: Gumbydammit]
#773017
08/13/10 07:35 PM
08/13/10 07:35 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
I would like to know too! I have one waiting on the bench for this conversion!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: Gumbydammit]
#773021
08/14/10 02:02 PM
08/14/10 02:02 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
So what is this secret to converting a 950HP Holley for blow through use? SOME say it can be done in a matter of minutes. Spill it!
http://web.archive.org/web/20031025025448/http://www.hangar18fabrication.com/blowthru.html
[Re: goldmember]
#773022
08/14/10 03:00 PM
08/14/10 03:00 PM
Posts: 2,255 IL
furious70
IL
There's a big difference between making a few adjustments to make it run well WOT on a dyno vs. making it a great street carb that returns decent mpg N/A as well as working under full boost WOT. Hangar18 seems to be one of the best from what I've read for DIY
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: dizuster]
#773025
08/16/10 12:17 PM
08/16/10 12:17 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
I'm going to convert my Mighty Demon 825 to E85 blow through in the next few weeks...
I'll put a post up when I'm done what it took to make it work, and how it goes...
Thats awesome that you are diving into that project!
[Re: 67_Satellite]
#773026
08/27/10 04:29 PM
08/27/10 04:29 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
http://www.theturboforums.com/smf/index.php?topic=51153.0
Ditto. Nothing to it really, except for the fact that you gotta be willing to do alot of messing around, and in the end, its still gonna be finicky, like all carbs ever built.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Defbob]
#773027
08/27/10 05:16 PM
08/27/10 05:16 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I modified my 600DP. I have been getting great mileage with it, and I am not light on the throttle. The fuel consumption almost acts like it is n/a. grant it I have a stock sized cam, 8lbs boost going into a 383ci motor.
Funny when I got mine back it had 74 fornt jets, that was smaller than I had N/A
