Re: Low oil pressure problem
[Re: blown360]
#772945
08/13/10 09:05 PM
08/13/10 09:05 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Sounds like maybe there is too much clearance between the rockers.. Were these shimmed properly, and then rechecked after torqueing down the shaft.. Just my $0.00..
[Re: blown360]
#772946
08/14/10 01:35 AM
08/14/10 01:35 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Your having the typical over oiling problem when using true roller rockers like Harland Sharps, T&D and so on, not bushed rockers,on a single shaft. Try restricting it down some more, are you using two restrictor jets, one in each head or one in the T block going to both heads? One is probally better than two
[Re: dOrk !]
#772951
08/14/10 07:40 PM
08/14/10 07:40 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I just put on a set of HS also I was just in the garage priming the oil I have a .069 jet in each line and that is still WAY to much oil up top and I have the side clearence set at .012 so I will have to change jets
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
