Re: has ur pinion angle changed?
[Re: carolinacuda]
#772804
08/13/10 12:21 PM
08/13/10 12:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
how do i unwind or them or get them back to neutral? Makes drivin pretty rough, no rear suspension travel. When i hit a bump the snubber is up to the floor so it feels like im riding on blocks.
New springs
[Re: MR_P_BODY]
#772805
08/13/10 12:34 PM
08/13/10 12:34 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Did you look to see if the spring perches on the rearend housing are bent or broken?
[Re: GomangoCuda]
#772806
08/13/10 12:45 PM
08/13/10 12:45 PM
Posts: 2,679 owt west
Thread Ender1
owt west
I can just about bet that the housing is twisting.
[Re: carolinacuda]
#772808
08/13/10 10:32 PM
08/13/10 10:32 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I noticed the other day that my pinion angle has changed. My pinion snubber was about 1 1/2 inches below my floor pan. Now the snubber is up against the floor. My pinion seal is leaking now, great..just had the rear rebuilt bout a yr ago. Anyone ever had this issue? Everything looks straight. Could the issue be weak springs (which are original by the way).
What rear end? I've seen Dana's with broken plug welds spin the housing. The weld were springy enough to allow it to somewhat spring back, but not before destroying a drive shaft, pinion yoke and overrunning clutch. Could also be the perches, or fatigued springs.
