Re: Why a tenth off when deep staging
[Re: Cab_Burge]
#772721
08/13/10 01:06 AM
08/13/10 01:06 AM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
Less rolling time(head start)to the start timers How is your reaction time deep versus shallow Lots oof ways to skin the kitty Training yourself to the difference in leaving on time(not red ) is the key to succes either way BTW, old dogs and new tricks are not to be used in the same sentence on the same day
My RT just staging on a .400 pro tree foot braking is .009 to .020. Deep, Ive tried a couple times now. Is .395 red to .00x.
[Re: 9 Sec Phill]
#772723
08/13/10 01:10 AM
08/13/10 01:10 AM
Posts: 7,506 Az
Crizila
Az
You're not covering less ground - from a 1/4 mile standpoint. When you shallow stage you are tripping the lights ( starting the timer )from a faster roll than when you deep stage.
Fastest 300
[Re: 9 Sec Phill]
#772724
08/13/10 01:12 AM
08/13/10 01:12 AM
Posts: 11,668 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Shallow staging gives you a running start at the starting line. Depending on the diameter of your front tire, your car has to move about 6-8 inches before the tire comes out of the beam; enough distance that you have some speed when that occurs. Deep staging causes your rate of travel to be slower when the tire comes out of the beam. If it costs you a full tenth, you must have tall front tires or the starting line beams at your track may be set a tad high. You will also see a difference in your reaction times by staging the car differently.
[Re: 9 Sec Phill]
#772729
08/13/10 11:30 AM
08/13/10 11:30 AM
Posts: 3,441 Mo.
supercomp
Mo.
Thanks all, was told this before but age is getting the best of me...Phill
If your redlighting on a .400 pro tree with a footbrake your age ain't affecting your reflexes any.
