Tire spin #772711
08/13/10 12:35 AM
08/13/10 12:35 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Will tire spin kill your mph in the1/4 mile?
Re: Tire spin [Re: Cape] #772712
08/13/10 12:49 AM
08/13/10 12:49 AM
it depends on where it is spinning I have seen tire spin on the starting line have better MPH than when it dead hook, this is on a slower car that runs low elevens I have a friend who races a twin turbo car that has spun the tires at the 1000 FT mark bad enough that he had to lift which did affect the MPH Any time you have to lift the throttle is going to affect MPH and ET
Re: Tire spin [Re: Cape] #772713
08/13/10 12:50 AM
08/13/10 12:50 AM
Renton Washington
Triple Threat Offline
Renton Washington
Depends on how bad you spin, but usually mph will go up slightly.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Tire spin [Re: Cab_Burge] #772714
08/13/10 12:52 AM
08/13/10 12:52 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
If my old car spun it would have a higher MPH. If it dead hooked a 1.36 60 the MPH would be 134. If it spun on the line it could be as high as 137.MPH...Phill
Re: Tire spin [Re: Cape] #772715
08/13/10 12:57 AM
08/13/10 12:57 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, if you can spin them the entire 1/4 mile Seriously, A small amount of tire spin will have very little effect on your MPH and can actually improve it if you are under geared.
Fastest 300
Re: Tire spin [Re: Cape] #772716
08/13/10 12:57 AM
08/13/10 12:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Usually it will be higher
Re: Tire spin [Re: Cab_Burge] #772717
08/13/10 02:30 AM
08/13/10 02:30 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks. Ya when I went to the track I had tire spin through every gear. Off the line spin hit second it grabbed but as the rpm climbed they started to spin and the same through 3rd and 4th
