You've chosen a fairly mild cam for a stroker so I assume that you plan on fairly modest compression ratio as well. Something pump gas friendly on the order of 10:1 give or take a little. If this is the case you don't need really big ports eg. Indy 360-1s, W8s etc. I think you will be fine with any of the Edelbrock heads, LA, Magnum, or Indybrocks. Based on my experience you will be better off buying them bare from a competent engine builder/ distributor and having them prep the heads and put quality valves in them. Fully ported and prepped any of these heads will supply all the air flow you need [ close to 300 cfm on intakes ] and still have excellent velocity.
