Re: alternators [Re: mopar dave] #772205
08/17/10 12:27 PM
08/17/10 12:27 PM
Az
Crizila Offline
Crizila  Offline
Az
went to the alt/starter shop yesterday. the guy pulled out a denso 80 amp from a 4 runner,rebuilt. pulley is correct and should bolt up without to much trouble. he's looking for an internal reg. to mount inside and let me know. $125 total. what do ya think?
See if he will give you an output curve with it. than you have enough info to figure out the correct pulley size you will need to cover your amp draw at your idle speed. Otherwise, it's a guess.
Fastest 300
Re: alternators [Re: Crizila] #772206
08/17/10 03:21 PM
08/17/10 03:21 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
well, i just picked it up. i had him bench test and at idle it has 70amp output and 115amp total when spun up. internal reg. pre set at 14.5v. only requires bat. lead hook up. now i just need to figure what brackets it will take to bolt it up.
Re: alternators [Re: mopar dave] #772207
08/17/10 08:47 PM
08/17/10 08:47 PM
Az
Crizila Offline
Crizila  Offline
Az
That's a lot of juice! Sounds like your good to go. Your ignition system will thank you
Fastest 300
Re: alternators [Re: mopar dave] #772208
08/18/10 12:51 AM
08/18/10 12:51 AM
AndyF Online content
AndyF  Online Content
Mancini Racing has the correct brackets to hang a Denso alternator on a Hemi, big block or small block.
Re: alternators [Re: AndyF] #772209
08/18/10 04:33 PM
08/18/10 04:33 PM
Mt Morris Michigan
Mt Morris Michigan
its mounted and looks nice. did'nt have to buy any new brackets,just had to use an old lower bracket on the bottom where the adjustment is made. i'll try it out tomorrow and see how well it puts out.
Re: alternators [Re: mopar dave] #772210
08/19/10 03:16 PM
08/19/10 03:16 PM
Mt Morris Michigan
Mt Morris Michigan
alt. works good. 14.3 output at alt. with everything on, 13.3 at the battery in the trunk. 13 going down the road, so looks good. currently charging the battery and will go for a cruise tomorrow.
Re: alternators [Re: mopar dave] #772211
08/19/10 03:17 PM
08/19/10 03:17 PM
Mt Morris Michigan
Mt Morris Michigan
another.
Re: alternators [Re: mopar dave] #772212
08/19/10 04:44 PM
08/19/10 04:44 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
How many amps are the square back dual field altenators?
Re: alternators [Re: mopar dave] #772213
08/20/10 02:09 AM
08/20/10 02:09 AM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
Mopar Dave what bottom pulley are you using on the engine? thanks Bradley
Re: alternators [Re: justinp61] #772214
08/20/10 12:52 PM
08/20/10 12:52 PM
Mt Morris Michigan
Mt Morris Michigan
i think the square backs are 75 amp.
Re: alternators [Re: mopar dave] #772215
08/20/10 12:54 PM
08/20/10 12:54 PM
Mt Morris Michigan
Mt Morris Michigan
my pulley kit is a march standard kit. crank pulley measures 5 7/8 dia.
Re: alternators [Re: mopar dave] #772216
08/21/10 09:04 AM
08/21/10 09:04 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Mopar dave what is the name and phone no of the shop that did your alternator?
Re: alternators [Re: mopar dave] #772217
08/21/10 09:21 AM
08/21/10 09:21 AM
NC
440Jim Offline
440Jim  Offline
NC
When you first mentioned changing the alternator pulley, I thought you were going to put a V-belt on it. But now I see the serpentine belt, and I like the look.
Re: alternators [Re: gtx69] #772218
08/21/10 07:18 PM
08/21/10 07:18 PM
Mt Morris Michigan
Mt Morris Michigan
super starter shop,flint mi: 810-767-7300. i requested an alt. from a 89-90 toyota 4 runner and this is what i got.
Re: alternators [Re: 440Jim] #772219
08/21/10 07:20 PM
08/21/10 07:20 PM
Mt Morris Michigan
Mt Morris Michigan
i'v been using a serpentine setup for a few years now and i like them over the v style. this alt. came with the correct pulley and was easy to get everything lined up good.
