18" wheels on a challenger #771350
08/11/10 12:08 PM
08/11/10 12:08 PM
W. Bloomfield, MI
71340vert Offline OP
W. Bloomfield, MI
What is the largest size wheel that will fit on a challenger and what back spacing do I need for the front and rear. I plan to go with a wider wheel in the back
Re: 18" wheels on a challenger [Re: 71340vert] #771351
08/11/10 01:31 PM
08/11/10 01:31 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I assume you mean an early [70-74] model. 'Cudas and Challengers should be pretty much the same. I run 17x8s with 5 in. backspace. I think 18s should fit Ok as well. I think you should be safe with 9 in. width and 5 1/2 in. backspace. You might get away with a little more backspace on the front. You MIGHT be able to even get away with 5 3/4 in. at the rear with low profile tires, but that would be pushing it.
