Page 1 of 4 1 2 3 4
Ray Barton 528 failure what to look for, what happened #771265
08/11/10 11:59 AM
08/11/10 11:59 AM
Illinois
ChrisDavis Offline OP
Illinois
It is not under the best of circumstances that I write this post. In 2007 I had Ray Barton build me a 528 for my ‘Cuda. To date it has 611 miles on it and no racing. I have changed the oil each year at about 200 mile increments. Recently it appears that I have a case of bearing failure.
About the engine:
It is the usual Ray Barton recipe of 528 cubes on a Mopar brand cast iron block, solid flat tappet cam (280*, 667”), Nascar lifters, Ray Barton rocker arms, aluminum heads, dual quad single plane, etc. It dyno’ed at 702 HP at near 7K RPM. I have it rev limited at 7K RPM as well.
Here are my issues:
Suddenly I lost oil pressure. It would always run about 60 Lbs. and now it is more like 20 Lbs. At about the same time it lost a couple hundred RPM off it’s idle. When I drained the oil it was black and looked like it had way more than 200 miles on it. Former oil changes where clean. There were some fine metal particles on the magnetic oil plug. When I cut the filter open I found a lot of gold colored metal in the pleats. This weekend I will be pulling the pan and bearing caps to see what might have failed.
Does anyone have any suggestions what I should look for besides the obvious bearing damage? Does anyone have any ideas what might have happened and why this failure took place? Does anyone else have experience with Ray Barton engines and their quirks?
Re: Ray Barton 528 failure what to look for, what happened [Re: ChrisDavis] #771266
08/11/10 12:17 PM
08/11/10 12:17 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
When you drained the oil, did it smell like gas?
Re: Ray Barton 528 failure what to look for, what happened [Re: Pat_Whalen] #771267
08/11/10 12:19 PM
08/11/10 12:19 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Sorry talk to Ted at Opel Eng, tell him its another RB engine. http://www.opelengineering.com/?page=dyno
Re: Ray Barton 528 failure what to look for, what happened [Re: Pat_Whalen] #771268
08/11/10 12:20 PM
08/11/10 12:20 PM
Illinois
Illinois
I didn’t notice any gas smell and I did have my face in the drain pan looking for anything in the oil.
Re: Ray Barton 528 failure what to look for, what happened [Re: ademon] #771269
08/11/10 12:21 PM
08/11/10 12:21 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
BTW they are in Streamwood IL
Re: Ray Barton 528 failure what to look for, what happened [Re: ademon] #771270
08/11/10 12:35 PM
08/11/10 12:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Do you have a teenage son?
Sorry to hear your engine is not well.
I'd be very tempted to pull it rather than just pull the pan and check bearings. A clean engine is a happy engine and all that stuff is inside.
I would pull the dist. and check the gear. Brass shavings.....
Re: Ray Barton 528 failure what to look for, what happened [Re: RodStRace] #771271
08/11/10 12:43 PM
08/11/10 12:43 PM
NY usa
540challenger Offline
NY usa
Pull the dist. Check the gear. I have had a few customers that the gear would wear. In turn it changes the speed since now the timing is change and with a lower idle the oil psi will drop. Sometimes does bronze gears last forever other times you almost want tpo change them every oil change. If it is the gear, in the future check the timing every so often when it starts to change the gear is wearing.
Re: Ray Barton 528 failure what to look for, what happened [Re: 540challenger] #771272
08/11/10 12:45 PM
08/11/10 12:45 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Can you post pictures of the wear surfaces and backs of the bearings? Rods and mains...
Re: Ray Barton 528 failure what to look for, what happened [Re: moper] #771273
08/11/10 12:53 PM
08/11/10 12:53 PM
Illinois
Illinois
I will post pictures after I pull the bearing caps and inspect the bearings.
This is a flat tappet cam and the distributor does not use a bronze sacrificial gear. The distributor gear is what comes stock on an MSD Pro Billet.
Re: Ray Barton 528 failure what to look for, what happened [Re: ChrisDavis] #771274
08/11/10 12:58 PM
08/11/10 12:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What brand of oil filter are you using?
Re: Ray Barton 528 failure what to look for, what happened [Re: stumpy] #771275
08/11/10 12:59 PM
08/11/10 12:59 PM
Illinois
Illinois
K&N. Wow do they have a thick case. I had a dificult time cutting it open.
Re: Ray Barton 528 failure what to look for, what happened [Re: ChrisDavis] #771276
08/11/10 01:06 PM
08/11/10 01:06 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Don't take it back to RB. I've heard stories that he'll tear it down, blame you ( Even if it's their fault they won't tell you they screwed up ), then stick you for the bill and hold your engine/parts hostage until you pay up.
Re: Ray Barton 528 failure what to look for, what happened [Re: 64Post] #771277
08/11/10 04:59 PM
08/11/10 04:59 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
run from Ray Baton,He ripped me bad.Thats why he does chevy engines now.
Re: Ray Barton 528 failure what to look for, what happened [Re: ChrisDavis] #771278
08/11/10 05:11 PM
08/11/10 05:11 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
There is no distributor gear on a mopar dist, it's a seperate part.
Good luck with Ray, did you try calling Barton before dragging him thru the mud?
i had a good friend , RIP , that had barton build him 2 motors , first was a hemi , no issues that I knew of , second was a 500" RB for his drag car, he had to take that motor back at least twice for problems that were caused by bad assembly.
Re: Ray Barton 528 failure what to look for, what happened [Re: JohnRR] #771279
08/11/10 05:13 PM
08/11/10 05:13 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Good Point.
Re: Ray Barton 528 failure what to look for, what happened [Re: 540DUSTER] #771280
08/11/10 05:18 PM
08/11/10 05:18 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Ray built my 477 hemi. Made 10 7k plus RPM dyno pulls in the 790+ HP range in 2005. has been in the car ever since. Runs faster every year. and all i do is change the oil and check the lash. every time it sits longer then two weeks i prime the oil pump to make sure it has instant oil pressure.
Re: Ray Barton 528 failure what to look for, what happened [Re: prochargedhemi] #771281
08/11/10 05:30 PM
08/11/10 05:30 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
A buddy of mine recently had a K&N oil filter fail immediately after installation on a GM product. He changed the oil, pulled off an AC Delco filter, put on the KN, fired it up and no oil pressure. Tried multiple restarts, nothing. Put the old/used Delco back on, and had instant oil pressure.
Not defending RB in any way, whatever it is, is what it is...but it might be a crappy oil filter
Rich H.
Esse Quam Videri
Re: Ray Barton 528 failure what to look for, what happened [Re: ZIPPY] #771282
08/11/10 05:54 PM
08/11/10 05:54 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds like the oil filter is working pretty good since it's full of bearing material.
Re: Ray Barton 528 failure what to look for, what happened [Re: ZIPPY] #771283
08/11/10 05:57 PM
08/11/10 05:57 PM
Illinois
Illinois
I have called Ray Barton. I don't recall saying anything bad about him in my posts. You must be referring to other peoples posts.
I had forgotten about the gear not being on the distributor. Too many years working on Chevy's. I would not expect that gear to be made of bronze since this is not a roller cam, but I could be wrong. If all that metal in the filter came from that gear then there can't be much gear left. There is an awful lot of metal in the filter.
Also there was no difference in oil pressure when I changed oil filters. K&N makes a very good filter, however I could see one plug up quicker than other brands since they trap smaller particles than other brands.
Re: Ray Barton 528 failure what to look for, what happened [Re: ChrisDavis] #771284
08/11/10 05:59 PM
08/11/10 05:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
I agree with everything you said. Sorry about your trouble.
Page 1 of 4 1 2 3 4
