Valve spring retainer question #771236
08/11/10 11:55 AM
08/11/10 11:55 AM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
Hi,
Trying to do a low buck refresh of a '86 318 for an occasional use truck. I'm trying to replace the valve stem seals (heads on the block) with a spring compressor, but the retainers seem stuck in the spring keeper even with the spring compressed.
I'm thinking they are varnished in there with the oil and heat over the years. Anybody used any good techniques to grab the spring retainers to remove the valve spring? I'm using an air compressor to try to keep pressure in the cylinder (closing the valve), but can't win.
Is there some trick I don't know. Any help appreciated.
Thanks! JK
mity225@mchsi.com
Always looking for my next project!
Re: Valve spring retainer question [Re: mity225] #771237
08/11/10 12:29 PM
08/11/10 12:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I always whack the corner of retainer a few times with a small hammer to break them loose beforehand. It is common for them to be stuck.
Re: Valve spring retainer question [Re: buildanother] #771238
08/11/10 12:37 PM
08/11/10 12:37 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Works fine for me that way too. Never hurt anything either.
Re: Valve spring retainer question [Re: mity225] #771239
08/11/10 02:00 PM
08/11/10 02:00 PM
Under My Car
Mopar_Country Offline
Under My Car
Give each retainer a slight whack with a hammer, then when you compress the spring the retainer should come loose from the locks.
Re: Valve spring retainer question [Re: Mopar_Country] #771240
08/11/10 04:57 PM
08/11/10 04:57 PM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
Great suggestions. I didn't use the hammer right. I tried to use a screwdriver to jam the retainer. I like the socket idea.
While finding this post, I found this one too that had some good ideas: https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6115762&Main=6115249
I'll try it this weekend. Thanks, JK
Re: Valve spring retainer question [Re: mity225] #771241
08/11/10 05:08 PM
08/11/10 05:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I usually hit them with a small hammer first.Then when I compress the spring I have a small pick and a small extendable magnet.Both come in handy especially with my bad hands from 40 years of wrenching.One usually comes right out and you have to turn and play with the second one.Dont forget to have the piston all the way up and air or rope in the cylinder.Rocky
Chrysler Firepower
