Horn ring 1965 Coronet #771099
08/11/10 05:37 AM
08/11/10 05:37 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi,
Just purchased a new steering wheel to my 65 coronet. Unfortnely I missing the part which the horn ring should attach to. I have the correct horn ring, horn switch with tree screws and steering wheel.
Is this the adaptor/center piece I need?
http://cgi.ebay.com/ebaymotors/65-66...Q5fAccessories
What could I expect to pay for just the adaptor/center piece...
Thanks,
Cheers!
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
Re: Horn ring 1965 Coronet [Re: Snoddas] #771100
08/11/10 01:12 PM
08/11/10 01:12 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
That link isn't showing anythign anymore. You have everything except the cap if I am understanding you corretly. IS that what a 65 coronet has, a round cap right?
Put the horn switch in place, then lay the metal ring peice over it, then place the three plastic bushings in the holes and attach with the three screws.
Hope that helped, but I may have missed something.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Horn ring 1965 Coronet [Re: Snoddas] #771101
08/11/10 01:14 PM
08/11/10 01:14 PM
Sparta, TN
mark42202 Offline
mark42202  Offline
Sparta, TN
Yes the item in the pic is what you need. As far as price, I'm not sure but it shouldn't be more than about 20-30 dollars.
Re: Horn ring 1965 Coronet [Re: mark42202] #771102
08/11/10 01:27 PM
08/11/10 01:27 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
Looks like the only thing you're missing is the center cap.
Re: Horn ring 1965 Coronet [Re: HitIt] #771103
08/11/10 04:00 PM
08/11/10 04:00 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
The steering wheel who was in the car before had a round cap. That centrum have to large diameter and also nothing to attach the horn ring on. See picture.
Re: Horn ring 1965 Coronet [Re: Snoddas] #771104
08/11/10 05:58 PM
08/11/10 05:58 PM
Sparta, TN
mark42202 Offline
mark42202  Offline
Sparta, TN
The gray metal ring is what the horn ring attaches to. The three tabs on the horn ring snap under the three raised portions of the gray ring.
Re: Horn ring 1965 Coronet [Re: mark42202] #771105
08/11/10 06:27 PM
08/11/10 06:27 PM
Andrewh Offline
Andrewh  Offline
here it is assembled.
I changed out my screws because the heads were stripped.
Re: Horn ring 1965 Coronet [Re: Andrewh] #771106
08/12/10 12:55 AM
08/12/10 12:55 AM
plumbeeper Offline
plumbeeper  Offline
You have to "spin" the horn ring onto the gray adapter to lock it on. Clockwise to put on, counter clockwise to remove.
Re: Horn ring 1965 Coronet [Re: plumbeeper] #771107
08/12/10 02:24 AM
08/12/10 02:24 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Thanks guys,
Have been offered to buy a correct part for attach the horn ring.
The one I have is for center cap and dont have any "ears" to lock at.
Cheers!
Re: Horn ring 1965 Coronet [Re: Snoddas] #771108
08/15/10 01:17 PM
08/15/10 01:17 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
This is how it should look like and P/N 2530 256
Have done some research. Hope its correct.
