Are aluminum case a833 trannys useless #771076
08/11/10 01:15 AM
08/11/10 01:15 AM
east bay ca
torqueaddict Offline OP
east bay ca
Are aluminum case a833 trannys useless or can they be modified to handle more power
Re: Are aluminum case a833 trannys useless [Re: torqueaddict] #771077
08/11/10 01:24 AM
08/11/10 01:24 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
See my post in this thread for info on the aluminum cases.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Are aluminum case a833 trannys useless [Re: torqueaddict] #771078
08/11/10 02:26 AM
08/11/10 02:26 AM
AndyF Offline
AndyF  Offline
Works fine for road racing behind 427 inches.
Re: Are aluminum case a833 trannys useless [Re: torqueaddict] #771079
08/11/10 02:37 AM
08/11/10 02:37 AM
Yeah, there useless. send mwe yours and I'll rpelace it with a cast steel case that will take a lot of abuse Just kidding of course, all the old Mopar pro stock cars and a lot of the other drag cars used the Mopar aluminum main and tailshaft cases for racing
Re: Are aluminum case a833 trannys useless [Re: Cab_Burge] #771080
08/11/10 03:32 AM
08/11/10 03:32 AM
east bay ca
east bay ca
The tranny I have has an iron tail and just the box is aluminum DaytonaTurbo I read you thread how expensive are the parts to make these high hp friendly. I guess if those ork you can go 4.11 gears and ride on the freeway easily huh
Re: Are aluminum case a833 trannys useless [Re: torqueaddict] #771081
08/11/10 10:02 AM
08/11/10 10:02 AM
wa
K
kensmachine Offline
kensmachine  Offline
K
wa
I have done a few of these transmissions for a road raceing freind. we take the od guts out and put the 71and up gear sets in. but the thing that must be done is bush the counter shaft bores as all of the ones I have seen have been bad. I think the aluminum factory race trannys had bushings in them from the factory Ken
Re: Are aluminum case a833 trannys useless [Re: kensmachine] #771082
08/11/10 12:53 PM
08/11/10 12:53 PM
South Lyon, Michigan
6bblRoadrunner Offline
I had Liberty bush my aluminum case.
