B&M flexplate for 904 #770961
08/10/10 10:14 PM
08/10/10 10:14 PM
ohio
dart70 Offline OP
dart70  Offline OP
ohio
Will a B&M 10230 flexplate work with a 904 transmission. It is slighly larger diameter than the 10231 that I was using on my old externally balanced engine combo. I know it will bolt up but am worried that there we be a interference problem with the starter.
Re: B&M flexplate for 904 [Re: dart70] #770962
08/10/10 10:18 PM
08/10/10 10:18 PM
K
Kiddart Offline
Kiddart  Offline
K
yes you will have to ut it down
Thank you
Kiddart
