'89 LeBaron 2.5 turbo engine problem
#770787
08/10/10 06:19 PM
08/10/10 06:19 PM
Posts: 1,128 Tulsa, OK
73cudaproject
Tulsa, OK
My son and I are working on an '89 Lebaron with a 2.5L turbocharged motor. We have a decent Ethos scan tool and are not reading any codes. When cold the motor starts fine and then after running for about 15 seconds begins to run poorly and almost dies when in park and given gas. The car was parked for a long time so we replaced the old gas with fresh gas, checked fuel pressure, replace fuel filter, checked spark plugs, etc. Any thoughts?
Re: '89 LeBaron 2.5 tubo engine problem
[Re: 73cudaproject]
#770788
08/10/10 06:26 PM
08/10/10 06:26 PM
Posts: 1,095 Bloomington, Illernoise
cptn60
Try unplugging temperature sensor connector and then start the car. You can also cycle the ign cylinder 3 times; then turn on and count CEL flashes. That's as much as I know, hope this helps.
This space available for rent
[Re: Tom Hand]
#770793
08/12/10 11:59 AM
08/12/10 11:59 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
While you're messing with the regulator, replace the feed and return lines running from the firewall to the fuel rail. Those lines tend to crack with age. If they split and dump fuel on a 1400 degree turbo things get ugly. Plenty of those cars burned because of that. Be sure to use a high pressure fuel injection hose.
[Re: feets]
#770794
08/12/10 06:48 PM
08/12/10 06:48 PM
DaytonaTurbo
Manitoba, Canada
Yep, same thing happened to my buddy's 87 daytona several years back. Luckily all he burnt up was an injector harness. Swapped that out and a new hose on and away he went.
