caltrac and trans brake?
#770342
08/09/10 11:49 PM
08/09/10 11:49 PM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
hi all, I experimented with luanch rpm on the weekend, 67 cuda 440, 610 dyno horse at 574 foot pounds of tourqe at 4700 rpm, with a 4600 8 inch stall. Previous set up was launching off the stall at 3800 rpm, calvert bars just touching and in the lower hole. Car ran a consistent 10.23 with low 1.4 60,s. Set the launch at 4400 rpm, 60,s fell off to high 1.4,s and the odd 1.55 and 1.557,s, but i still managed some 10.22,s and the odd 10.3, car seemed very inconsistent. I never experimented with the bars at all and by pure luck I went into the semis, with a 90 or so car field. Any ideas on what I should try with the bars next time out or go back to the way I had it. I should state i,m using 29. by 12 15 good years with 11 psi and 471 moser gears.Just trying to get a little more out of the package, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: caltrac and trans brake?
[Re: Islandcuda]
#770343
08/10/10 02:55 PM
08/10/10 02:55 PM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
Tim, you have a lot going on here. At first glance, bumping the rpm up with the same track conditions and experiencing what you did is consistent with a track that may be getting too hot. The hotter the track gets, the softer the hit should be to the tire to maintain traction. This will incorportate different shock settings, and the such. Or another version of the above could include a 'poorly prepped' track vs. a 'well prepped' track. Poor prep = softer hit (rpm, shock settings, preload) Well prepped = harder hit (more rpm, stiffer shock settings, less preload)Caltracs' baseline settings are typically designed for the street strip footbraker. My I see you have a 4600 8" stall, but do you know what the converter will flash too? Tell us more about your combo: shocks and if adjustable, what settings your tranny How much travel in the front end I expect you are using a spool Car weight And not to cause any debate, but what is your pinion angle set at? To get back to your question though, I would put your launch RPM back to 3800. Make changes of 200 RPM increments (My opinion). I think a 1.4 60 with your combo and first time use with caltracs/transbrake are pretty good numbers!
[Re: Plumcrazyracing]
#770344
08/10/10 09:55 PM
08/10/10 09:55 PM
Islandcuda
good advice plumcrazy, i should astate that i,ve had caltracs on for awhile with the mono leaf , trans brake is fairly new last year but only 3 races. 727 with all the good parts, caltrac front shocks on the front, rancho on the rear set at 7, car weight of 2800, not sure what flash stall is , tried to figure it out but just don,t get it ,lol.Can,t remember pinion angle but it was good last time i checked, thinking 3 degrees down was it.
[Re: Islandcuda]
#770347
08/12/10 03:23 AM
08/12/10 03:23 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
With the HP and torque you have, you may be hitting the track too hard/quick with your 471 gears to get a good consistent bite. It is likely you would get a more consistent launch without hurting ET's with a 4.30 gear or even a 4.10. You already have a converter getting you into the power band of your motor with the 4600 stall. . Your car (67 A-body) should be light enough you can use the torque of the motor to get you off the line hard rather than the rear gear. I know I had real good luck getting a consistent launch with my big block (512cid) #2850 70 Cuda with 720hp running a 3.89 gear and a 32x14.5 tire. 1.21-1.23 60' times. With more gear, an "iffy" track can get real tricky in the first 60'.
[Re: Dodgem]
#770349
08/12/10 11:35 PM
08/12/10 11:35 PM
Islandcuda
funny you should mention that, before I put the brake in,I was foot breaking, with a 4.56 gear I was low 1.4,s and the odd 1.39 on my 60 foot. I was consistent 10.15 and 18,s.I anialated my 8 3/4 on the line and the only moser unit to go with the 9 inch i put in at the time had the 4.71,s, that is why they are in the car now.
