Aluminum Vs. Graphite Block #769735
08/09/10 04:45 PM
08/09/10 04:45 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Looking at the aluminum and CG blocks. What are the pros and cons of each for a 625hp-ish street strip engine? Is the CG block way overkill for this much power? Why do they no longer make these CG blocks?
Thanks!
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Aluminum Vs. Graphite Block [Re: HitIt] #769736
08/09/10 05:06 PM
08/09/10 05:06 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
I would say that a CG block would be way overkill for the HP your talking about. Actually I would say the aluminum block would be too. A stock block or one of the World iron blocks would be fine for that hp.
LBSR
Re: Aluminum Vs. Graphite Block [Re: Bill_LBSR] #769737
08/09/10 06:41 PM
08/09/10 06:41 PM
fullmetaljacket Offline
A little abstract in explanation, but here goes.
Like said above, you don't need any of the fancy stuff for that level.
Some here are pushing 700 plus HP on stock well tanked, cleaned, pressure tested, wall thickness consistency tested and machined to good round straight,squared and flat surfaces.
Re: Aluminum Vs. Graphite Block [Re: Bill_LBSR] #769738
08/09/10 06:41 PM
08/09/10 06:41 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
x2 stock would be the best bet. ligter than aftermarket steel less costly tan the others can withstand near double your 600 HP
home of the
Sox and Martin Hemi Duster
Re: Aluminum Vs. Graphite Block [Re: HEMIFRED] #769739
08/09/10 06:57 PM
08/09/10 06:57 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
X3 save you money for other things....
Re: Aluminum Vs. Graphite Block [Re: Diablo] #769740
08/09/10 08:04 PM
08/09/10 08:04 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
The reason CG block might become obsolete, isn't because of the any issues with the block itself, its the cost to machine it. They are very nasty on tool life. Also, if you did get one and wanted to go +.030" in the future, your engine builder might not like it either.
Re: Aluminum Vs. Graphite Block [Re: Dragula] #769741
08/09/10 09:12 PM
08/09/10 09:12 PM
Communist New York State, Comi...
W
We The People Offline
W
If I had a bunch O'cash I might use an alum. block on the street just for the low weight. but you dont need it for 625 hp. I run 660 in a stock 72 hp2 at the track.
Re: Aluminum Vs. Graphite Block [Re: We The People] #769742
08/09/10 09:20 PM
08/09/10 09:20 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
using aluminum does have horsepower loss issues
home of the
Re: Aluminum Vs. Graphite Block [Re: HEMIFRED] #769743
08/09/10 09:32 PM
08/09/10 09:32 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Fixable, though. I'd choose the aluminum block over the CG just for that.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Aluminum Vs. Graphite Block [Re: HEMIFRED] #769744
08/09/10 11:42 PM
08/09/10 11:42 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Far outweighed by weight loss and repairability .
Buy a block you can run and fix forever or buy a CG and hope for the best .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Aluminum Vs. Graphite Block [Re: go green] #769745
08/10/10 01:55 AM
08/10/10 01:55 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I would say the World block
Re: Aluminum Vs. Graphite Block [Re: Dragula] #769746
08/10/10 08:29 AM
08/10/10 08:29 AM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
Re: Aluminum Vs. Graphite Block [Re: BIG BEAR] #769747
08/10/10 12:58 PM
08/10/10 12:58 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Great info guys, thanks very much.
The reason I ask is that I can get a screaming deal on a new alumnium block wedge block, and the guy offered the GC block at the same price. Might still go aluminum but like you all say money could be spent in better places...
Thanks again!
Re: Aluminum Vs. Graphite Block [Re: HitIt] #769748
08/10/10 01:10 PM
08/10/10 01:10 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Carbon graphite takes diamonds, tungston, or carbide tooling to machine it. It also grows and shrinks much differently than aluminum or iron.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Aluminum Vs. Graphite Block [Re: HitIt] #769749
08/10/10 01:17 PM
08/10/10 01:17 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
HEMIFRED, I have heard of the horsepower loss with a aluminum engine. But with the new castings like the Indy Maxx blocks is this still true? This is only a question I am not disagreeing with you.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Aluminum Vs. Graphite Block [Re: MRMOPAR622] #769750
08/10/10 01:48 PM
08/10/10 01:48 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
yes to a point they all have some loss the only evaluation comes from similar combos as no one I know of ever did a mirror build to compare the two.
home of the
Re: Aluminum Vs. Graphite Block [Re: HEMIFRED] #769751
08/10/10 01:54 PM
08/10/10 01:54 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Why the difference in power?
Re: Aluminum Vs. Graphite Block [Re: HitIt] #769752
08/10/10 02:24 PM
08/10/10 02:24 PM
ring seal due to the differences in the expansion rate between the aluminum block and steel sleeves is what I have been told. I heard this from a relaible source that has used both types of block that the aluminum block would only hold minimum (less than 5 inches)vacume on start up cold and end up with positive crankcase pressue at the end of the run, 45 seconds to a minute and fifteen seconds later The iron block holds 17 inches on start up and crooses the finish line at 15 inches or more depending on how many runs are on the rings and pistons. This is on a boosted 2000+ HP motor IHTHs
Re: Aluminum Vs. Graphite Block [Re: Cab_Burge] #769753
08/10/10 02:38 PM
08/10/10 02:38 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Completely agree there is a loss with Alum blocks but i'm wondering how much closer a solid alum block is to a iron one compared to the water ones.
Both my TS engines have solid KB blocks. (but if i had the choice and there were iron 4.840bs blocks out there i probably would have gone with steel.
Re: Aluminum Vs. Graphite Block [Re: Diablo] #769754
08/10/10 03:29 PM
08/10/10 03:29 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have one more question. Do you think there is enought horespower advantage in a steel block to make up for the extra 100 lbs or so? Indy says the Maxx aluminum block is a 110 lbs lighter than the cast iron block.
No one has mention that yet. I was just curious.
How much extra horsepower would it take to make up a 100 lbs? I can't find my Moroso(sliderule) calculator.
