Do I have a forged or cast crank? #769684
08/09/10 03:06 PM
08/09/10 03:06 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I have a small block crankshaft that I got years ago that I was told at the time was a forged crank from a 340. I never bothered trying to verify it until now. The part number on it is 2658278 which according to the one chart I looked at is a 273-318 cast crank. However, based on the picture in the tech section showing the differences between cast and forged cranks it would appear it is a forged crank. It has the wide parting lines and the rounded edges but the part number looks more like that of a cast crank.
Re: Do I have a forged or cast crank? [Re: 1970RT] #769685
08/09/10 03:08 PM
08/09/10 03:08 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Tech picture.
Re: Do I have a forged or cast crank? [Re: 1970RT] #769686
08/09/10 06:49 PM
08/09/10 06:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I thought the 273 had a forged crank ?
Can you post a better , not so dark , picture of it ?
Re: Do I have a forged or cast crank? [Re: JohnRR] #769687
08/09/10 08:09 PM
08/09/10 08:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
forged, if you ask me
Re: Do I have a forged or cast crank? [Re: NachoRT74] #769688
08/09/10 08:17 PM
08/09/10 08:17 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
the edges look rounded on your orig pic so......... .......... forged crank
Re: Do I have a forged or cast crank? [Re: ngpSatellite] #769689
08/09/10 09:39 PM
08/09/10 09:39 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I don't know if it will help but here is another picture.
Re: Do I have a forged or cast crank? [Re: 1970RT] #769690
08/09/10 09:44 PM
08/09/10 09:44 PM
Texas
70Runnerdude Offline
Texas
Forged for sure
Re: Do I have a forged or cast crank? [Re: 70Runnerdude] #769691
08/09/10 09:50 PM
08/09/10 09:50 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Forged for sure
Re: Do I have a forged or cast crank? [Re: rrunner] #769692
08/09/10 10:00 PM
08/09/10 10:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what they said
Re: Do I have a forged or cast crank? [Re: JohnRR] #769693
08/09/10 10:05 PM
08/09/10 10:05 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Yup, forged.
Re: Do I have a forged or cast crank? [Re: vdriver] #769694
08/09/10 10:50 PM
08/09/10 10:50 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Can someone verify if the part number is for a forged crank? In the attached chart it indicates the part number on the crank I have as being a cast crank.
http://kim_spure.tripod.com/A-Engine.htm#Crank
Re: Do I have a forged or cast crank? [Re: 1970RT] #769695
08/09/10 11:23 PM
08/09/10 11:23 PM
Eastern ohio
Alexdodge Offline
Alexdodge  Offline
Eastern ohio
now, which damper go with which crank?
Re: Do I have a forged or cast crank? [Re: Alexdodge] #769696
08/10/10 12:30 AM
08/10/10 12:30 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
yup. it's forged...273 or 318. the 340 had the rod journals cross drilled. interchageable with a balance job.
Re: Do I have a forged or cast crank? [Re: 1970RT] #769697
08/10/10 01:10 AM
08/10/10 01:10 AM
Corona CA
wyotech_cuda440 Offline
Corona CA
Regardless of the P/N, that is a forged crank. It's easily determined by the wide parting line because it was slammed between two dies in a forge. If the two dies hit each other, the forge will destroy itself, so the dies stop short and leave a wider seam. The cast crank has a thin parting line, because the casting molds are held together tightly so the molten steel doesn't run out.
Daily driver: 2002 Dakota R/T, slightly modded Weekend machine: 70 cuda, 440-6 street/strip
Re: Do I have a forged or cast crank? [Re: wyotech_cuda440] #769698
08/10/10 09:25 AM
08/10/10 09:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said ... it doesn't matter what part number is on it , it's a FORGED CRANK
Re: Do I have a forged or cast crank? [Re: JohnRR] #769699
08/10/10 11:04 AM
08/10/10 11:04 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
O.K. Thanks everyone.
Re: Do I have a forged or cast crank? [Re: JohnRR] #769700
08/10/10 02:00 PM
08/10/10 02:00 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I totally agree. The pictures don't lie.
Now.............
Why the cast crank P/N?
And the 1st person that says "I've seen.... "
Re: Do I have a forged or cast crank? [Re: Commando1] #769701
08/10/10 04:15 PM
08/10/10 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I, too, am curious as to the part number, is it stamped or written or is the number raised?
Re: Do I have a forged or cast crank? [Re: John_Kunkel] #769702
08/10/10 10:38 PM
08/10/10 10:38 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Here is a picture of the number. It is raised but there are a couple of other numbers and letters that are stamped.
Re: Do I have a forged or cast crank? [Re: 1970RT] #769703
08/10/10 10:38 PM
08/10/10 10:38 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Stamped numbers and letters.
