BATTERY IN THE TRUNK WIRING #769573
08/09/10 11:46 AM
08/09/10 11:46 AM
Sterling Hts, MI
2
2FASTCORONET Offline OP
Sterling Hts, MI
I have a three wire altrernator in my car, can I run the heavy wire to the solenoid I have in the trunk and run it back to the front of the car and reconnect? Or is there a better way without rewiring my whole car for a one wire alternator? Thanks Dennis
Re: BATTERY IN THE TRUNK WIRING [Re: 2FASTCORONET] #769574
08/09/10 12:21 PM
08/09/10 12:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You run the main heavy (and since its a long way I suggest #6 or # 4 wire straight to the battery + then though the cut off switch back to the battery and on to the starter solenoid. some put other stuff in the mix??
Re: BATTERY IN THE TRUNK WIRING [Re: 2FASTCORONET] #769575
08/09/10 12:23 PM
08/09/10 12:23 PM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
Leave the alternator wired up like it is supposed to be. run a field wire to the kill switch,or solenoid.Then run it back to thes alt.
Dennis Jokela
I started out with nothing,and I still have most of it.
