Truck 8 3/4 worth saving? #769486
08/09/10 08:45 AM
08/09/10 08:45 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I'm parting a 72 D100 2wd. The truck has an 8 3/4 rear and I'm wondering if I should save the entire rearend or just pull the axles and center chunk. What do you guys think?
Re: Truck 8 3/4 worth saving? [Re: AeroMonte] #769487
08/09/10 09:18 AM
08/09/10 09:18 AM
scratchnfotraction Offline
IMHO,yes save the whole thing,they dont make them any more
the axle are most likly canadates for a cut and respline,have a larger flange end with the 5 on 5 1/2"wbp so it can be redrilled for the 5 on 4 1/2" wbp
the housing is a good canadate to have narrowed also
spring perches are on top of axle tube,but are 43" centers same as an A-body(I have an A-body 8 3/4 in my truck,tucks 12" rims and 29x15x15 m/t right in there)
my 72 4x4 truck 8 3/4 had a 489 with a 3.91sg in it
I save every one I can get a hold of myself
Re: Truck 8 3/4 worth saving? [Re: scratchnfotraction] #769488
08/09/10 09:43 AM
08/09/10 09:43 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
72 2 wheel drive = 4.5 bolt circle.
Re: Truck 8 3/4 worth saving? [Re: MoparforLife] #769489
08/09/10 10:29 AM
08/09/10 10:29 AM
yes they have both wbp for trucks
Re: Truck 8 3/4 worth saving? [Re: AeroMonte] #769490
08/09/10 11:37 AM
08/09/10 11:37 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'd keep it. they make a great replacement for the weaker 9 1/4".
Sheldon
Re: Truck 8 3/4 worth saving? [Re: RUNCHARGER] #769491
08/09/10 02:29 PM
08/09/10 02:29 PM
Under My Car
Mopar_Country Offline
Under My Car
Keep it!
Re: Truck 8 3/4 worth saving? [Re: scratchnfotraction] #769492
08/09/10 05:17 PM
08/09/10 05:17 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yes they do but I thought it was different by year.
ie 72+4.5
82=5.5
No?
But to the original question. I try to keep whatever I can get these days. If you have room keep it. Someone will need it if you don't.
Re: Truck 8 3/4 worth saving? [Re: bboogieart] #769493
08/09/10 06:39 PM
08/09/10 06:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
besides the 2 having the different bolt patterns the 65/71 is narrower than the 72/74.
I am truckless..
Re: Truck 8 3/4 worth saving? [Re: bboogieart] #769494
08/10/10 03:35 PM
08/10/10 03:35 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
ie 72+4.5
82=5.5
No?
The 8.75 axle used in 4 wheel drive trucks from 1969 through 1974 had the 5x5.5 bolt pattern. The 2 wheel drive trucks had the 5x4.5 bolt pattern.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Truck 8 3/4 worth saving? [Re: Soopernaut] #769495
08/10/10 04:15 PM
08/10/10 04:15 PM
the 2x trucks went 5x5.5 in 85 also on the 8 1/4-9 1/4 rear axles
so the 8 3/4 4x4 with the 5x5.5 is a good swap and still matches the stock rims
