8 - 3/4 center section - anyone seen this before ? #769436
08/09/10 02:34 AM
08/09/10 02:34 AM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
During the cleaning of the rear axle and 8-3/4 out of my 72 Challenger Rallye I made a discovery on the center section that I've never seen before (or maybe I have not been paying attention in over 25 years of wrenching on e-bodies)
This is a low mileage original car that I purchased from the original owner over 10 years ago while living out in cally so the underside is in excellent condition.
Check out photos of the 8 - 3/4 center section.
At first I thought it was rust but the more grease & dirt removed it became evident that the center is painted with red oxide primer. All the original paint markings and codes are on the axle tube, center section etc.
My experience has been that the center sections were finished (or left) natural steel.
Re: 8 - 3/4 center section - anyone seen this before ? [Re: C_B5] #769437
08/09/10 02:35 AM
08/09/10 02:35 AM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
another photo
Re: 8 - 3/4 center section - anyone seen this before ? [Re: C_B5] #769438
08/09/10 03:23 AM
08/09/10 03:23 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
probably rebuilt in the past, most i have seen are natural + the gear ratio tag is usually on the lower driver side, at least what i have seen
Re: 8 - 3/4 center section - anyone seen this before ? [Re: ademon] #769439
08/09/10 09:51 AM
08/09/10 09:51 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Might be that a dealer replaced it with a ratio requested by the new car owner.
Many similar things were done to please a customer. I bought a new 66 Plymouth, it had power steering that I didn't like, the dealer offered to replace it with a non power unit.
Re: 8 - 3/4 center section - anyone seen this before ? [Re: C_B5] #769440
08/09/10 09:57 AM
08/09/10 09:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
a buddy of mine has an nos center section . and it's red oxide as shown. so more than likely it's an over the counter install piece
Re: 8 - 3/4 center section - anyone seen this before ? [Re: gtx6970] #769441
08/09/10 10:32 AM
08/09/10 10:32 AM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
Did over-the-counter NOS units have all of the same markings as an OEM unit?...except for bolt-check paint dabs of course.
Re: 8 - 3/4 center section - anyone seen this before ? [Re: C_B5] #769442
08/09/10 11:04 AM
08/09/10 11:04 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, that is a production line piece. I found several '72-'74 units painted red oxide from the factory over the years.
Where was the car it came from built?
Re: 8 - 3/4 center section - anyone seen this before ? [Re: DoctorDiff] #769443
08/09/10 12:14 PM
08/09/10 12:14 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I have had several just like that out of '72-4 E-bodies.
Re: 8 - 3/4 center section - anyone seen this before ? [Re: 70440+6bbl] #769444
08/09/10 01:38 PM
08/09/10 01:38 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
I am almost sure my '67 was red oxide
Re: 8 - 3/4 center section - anyone seen this before ? [Re: DoctorDiff] #769445
08/09/10 02:02 PM
08/09/10 02:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
All 72-74 E-bodies were built at Hamtramck. I think all 71 E-bodies also (not 100% sure though)
Re: 8 - 3/4 center section - anyone seen this before ? [Re: autoxcuda] #769446
08/09/10 02:07 PM
08/09/10 02:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
All 71-74 E bodies were built at Hamtramck.
Re: 8 - 3/4 center section - anyone seen this before ? [Re: burdar] #769447
08/09/10 09:42 PM
08/09/10 09:42 PM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
Yes car built at Hamtramck. Plus I have no reason to believe that it was ever replaced or rebuilt.
The axle ratio is correct to the build sheet and all markings original.
Now that others have stated that the red oxide was on some of the cars I'm trying to remember if any of the other 72-74 e-bodies that I owned were like that as well
Re: 8 - 3/4 center section - anyone seen this before ? [Re: C_B5] #769448
08/09/10 10:27 PM
08/09/10 10:27 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I should have asked this question last year, after seeing an article on where to look for some markings,I started cleaning my 8.75, there is what looks like orange paint under some of the black that came off - I was always wondering why would someone strip the black, paint it reddish orange, and then black again - it's a 489 case 3.55 gear car was built May 26 of 71 - I'll have to look at the date to see what it is, havepicson my other computer - will post when I get a chance - interesting - Joe
Re: 8 - 3/4 center section - anyone seen this before ? [Re: burdar] #769449
08/09/10 10:48 PM
08/09/10 10:48 PM
middle of the country
aar1 Offline
aar1  Offline
Really? They only built them in L.A. for one year?
Re: 8 - 3/4 center section - anyone seen this before ? [Re: aar1] #769450
08/09/10 11:16 PM
08/09/10 11:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes
Re: 8 - 3/4 center section - anyone seen this before ? [Re: TWS] #769451
08/10/10 09:51 AM
08/10/10 09:51 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I don't remember if it had any other markings on it or not. it's a 2.76 open and now in his 1970 challenger. and if I remember right everything was red oxide including the pinion flange
