Re: Battery Hold Down??
[Re: mopowers]
#769069
08/08/10 08:40 PM
08/08/10 08:40 PM
Posts: 1,880 USA
Ron Silva
USA
If you use J hooks the ends need to be welded closed. 3/8 Minimum. I used 3/8 bolts and welded them to the base.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#769070
08/08/10 08:43 PM
08/08/10 08:43 PM
Posts: 1,880 USA
Ron Silva
USA
2
SRT DEMON ONE SEAT
[Re: Ron Silva]
#769071
08/08/10 08:53 PM
08/08/10 08:53 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I use 3/8" all thread, Used to have a plastic battery tray with 3/8" all thread secured with nut a washer top and bottom of trunk floor, perforated angle across the top. Now 1"x1" sq. tubing with all thread bolted through with a nut welded on the bottom, same top set up.
[Re: mopowers]
#769073
08/08/10 09:59 PM
08/08/10 09:59 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I used this Taylor box. It came with 3/8" ALL THREAD..is NHRA accepted,,therefore, I say 3/8" all thread is legal.
If you like drag racing, support your local track.
[Re: Ron Silva]
#769074
08/09/10 12:01 AM
08/09/10 12:01 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Thanks for the ideas guys. Is there a min. spec for the hold down strap? I was thinking of using a piece of 1/4" or 3/8" aluminum. Maybe 1" or 1 1/2" wide. Would this work? Quote:
You welded that frame/tray to the floor panel correct?
[Re: viperrt]
#769076
08/09/10 12:12 AM
08/09/10 12:12 AM
mopowers
Sac, CA
Here's a picture
That looks real good. What did you use for the hold down and tray?
[Re: mopowers]
#769077
08/09/10 12:23 AM
08/09/10 12:23 AM
Posts: 1,880 USA
Ron Silva
USA
Yes there are welds all the way around. You just can't see them because some are on the inside. That also happens to be right on top of the frame where I put added welds underneath frame to floor. I used 1/2" OR 3/4" square tubing. There is no requirement for the hold down strap that I know of. Common sense here says at least as strong as OEM and remember it is a race car and will potentially crash a lot harder than a road car.
SRT DEMON ONE SEAT
[Re: 70HemiGTX]
#769080
08/09/10 09:23 PM
08/09/10 09:23 PM
CHAPPER
Belpre,Ohio
"rules" call for the hold downs to be attached to the FRAME...I don't know how well that is enforced, but I did make brackets off the frame rail to bolt the hold downs to.
[Re: LA360]
#769082
08/09/10 11:07 PM
08/09/10 11:07 PM
CHAPPER
Belpre,Ohio
I have found it 'not good' to "argue" with tech inspectors!!! J/K
[Re: 70HemiGTX]
#769083
08/10/10 11:29 AM
08/10/10 11:29 AM
mopowers
Sac, CA
I used 3/8" studs. Threads on each end. Double nuts on bottom side of trunk floor and single nut on top of batter box (on floor of trunk). Then I got a piece of 1/4" stainless and had it bent to fit the battery. Plus my box is welded to the floor and frame.
That looks awesome. What did you paint your trunk with? It looks like spatter paint. What brand is it? How do you like it?
